소개
This replacement guide will show you how to access the battery terminal leads on a Fujifilm FinePix S5100 camera. It is recommended to use a magnetic pad to place the screws on in conjunction with the magnetic tools mentioned above. This is to prevent or minimize the chances of losing or misplacing a screw. Be mindful of this with regards to safe handling of the electrical components. This guide is fairly simple and does not require a large amount of time.
필요한 것
Orient the camera upside down with the lens facing to the left and the battery compartment facing directly toward you.
Turn the camera so the screen is facing you and the camera lens is facing away from you.
Remove the single 1.3mm Phillips #000 screw.
Carefully remove the battery compartment from the rest of the camera.
Remove two 0.6mm Phillips #000 screws from the metal battery terminal lead.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
hello, could you help me with the repair of the power button of a camera fuji finepix HS 20 EXR since the problem lies in the fact that after pressing the trigger and taking a photo, the camera turns off.
