소개
This replacement guide will show you how to access the LCD screen on a Fujifilm FinePix S5100 camera. It is recommended to use a magnetic pad to place the screws on in conjunction with the magnetic tools mentioned above. This is to prevent or minimize the chances of losing or misplacing a screw. The LCD screen is a delicate component so take care and use caution when handling it. Keep it away from hazardous liquids and other objects that may pose a risk to damage to the camera.
필요한 것
Orient the camera upside down with the lens facing to the left and the battery compartment facing directly toward you.
Turn the camera so the screen is facing you and the camera lens is facing away from you.
다른 한 분이 해당 안내서를 완성하였습니다.
