주요 콘텐츠로 건너뛰기
FujiFilm FinePix XP10SE Front Cover Replacement
필요한 것
  1. FujiFilm FinePix XP10SE Front Cover Replacement, Front Cover: 1 단계, 이미지 1/3 FujiFilm FinePix XP10SE Front Cover Replacement, Front Cover: 1 단계, 이미지 2/3 FujiFilm FinePix XP10SE Front Cover Replacement, Front Cover: 1 단계, 이미지 3/3
    • Use a screwdriver to remove the four screws from the top and bottom of the camera. Remove the screws securing the lanyard as well.
    • Use a T5 Torx bit to secure the exterior decorative cover of the device.
  2. FujiFilm FinePix XP10SE Front Cover Replacement: 2 단계, 이미지 1/2 FujiFilm FinePix XP10SE Front Cover Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool to detach the case.
  3. FujiFilm FinePix XP10SE Front Cover Replacement: 3 단계, 이미지 1/2 FujiFilm FinePix XP10SE Front Cover Replacement: 3 단계, 이미지 2/2
    • Use the plastic opening tool to cautiously pry the casing off of the camera.
  4. FujiFilm FinePix XP10SE Front Cover Replacement: 4 단계, 이미지 1/3 FujiFilm FinePix XP10SE Front Cover Replacement: 4 단계, 이미지 2/3 FujiFilm FinePix XP10SE Front Cover Replacement: 4 단계, 이미지 3/3
    • Carefully slide the case to the left. Avoid cracking the case on the lens.
결론
Bryan
회원 가입일: 01/25/15
598 평판
안내서 5개 작성하였습니다
Pasco Hernando, Team 5-1, Prince Winter 2015 Pasco Hernando, Team 5-1, Prince Winter 2015 회원
PHSC-PRINCE-W15S5G1
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 163
