주요 콘텐츠로 건너뛰기
Fujifilm FinePix Z90 Lens cover/case Replacement
필요한 것
  1. Fujifilm  FinePix Z90 Lens cover/case Replacement, Lens cover/case: 1 단계, 이미지 1/2 Fujifilm  FinePix Z90 Lens cover/case Replacement, Lens cover/case: 1 단계, 이미지 2/2
    • Use a small #000 Phillips screwdriver to take the screws out. Keep all the screws in a container and the two different types separate.
    • Remove the two screws on the right side.On the same side there is USB connector, open that little door and unscrew the little screw inside of it.
  2. Fujifilm  FinePix Z90 Lens cover/case Replacement: 2 단계, 이미지 1/2 Fujifilm  FinePix Z90 Lens cover/case Replacement: 2 단계, 이미지 2/2
    • Take the two screws on the left side and the two screws on the bottom of the camera.
  3. Fujifilm  FinePix Z90 Lens cover/case Replacement: 3 단계, 이미지 1/2 Fujifilm  FinePix Z90 Lens cover/case Replacement: 3 단계, 이미지 2/2
    • By now you will have the front case and the back case separated from each other.
결론
Sam Clark
회원 가입일: 11/03/15
301 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 1-6, Bhusal Fall 2015 UMass Dartmouth, Team 1-6, Bhusal Fall 2015 회원
UMASSD-BHUSAL-F15S1G6
2 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 268
