주요 콘텐츠로 건너뛰기
Fujifilm Endeavor 100ix Battery Door Replacement
필요한 것
  1. Fujifilm Endeavor 100ix Battery Door Replacement, Battery Door: 1 단계, 이미지 1/1
    • Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
  2. Fujifilm Endeavor 100ix Battery Door Replacement: 2 단계, 이미지 1/1
    • Locate the battery door.
  3. Fujifilm Endeavor 100ix Battery Door Replacement: 3 단계, 이미지 1/1
    • Locate the latch on the battery door.
    • Use your finger pry to it open where it says "BATT."
  4. Fujifilm Endeavor 100ix Battery Door Replacement: 4 단계, 이미지 1/1
    • Remove the battery from the camera by pulling the battery door outward.
  5. Fujifilm Endeavor 100ix Battery Door Replacement: 5 단계, 이미지 1/1
    • Locate and remove three black 3.80mm screws on the back of the black casing with the Phillips #00 screwdriver.
  6. Fujifilm Endeavor 100ix Battery Door Replacement: 6 단계, 이미지 1/1
    • Squeeze the camera placing a thumb on the tab marked CE.
    • Pull the back half of the camera firmly away from the camera body.
  7. Fujifilm Endeavor 100ix Battery Door Replacement: 7 단계, 이미지 1/2 Fujifilm Endeavor 100ix Battery Door Replacement: 7 단계, 이미지 2/2
    • Locate and remove the 3.80mm screw that holds the plastic strip to the camera body with a Phillips #00 screwdriver.
    • The plastic strip will now come off the camera body.
결론
Eric Nicolai
회원 가입일: 01/10/11
679 평판
안내서 6개 작성하였습니다
Cal Poly, Team 13-5, Forte Winter 2011 Cal Poly, Team 13-5, Forte Winter 2011 회원
CPSU-FORTE-W11S13G5
5 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 1,863
