주요 콘텐츠로 건너뛰기
Fujifilm Endeavor 100ix Power Button Replacement
필요한 것
  1. Fujifilm Endeavor 100ix Power Button Replacement, Outer Casing: 1 단계, 이미지 1/1
    • Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
  2. Fujifilm Endeavor 100ix Power Button Replacement: 2 단계, 이미지 1/1
    • Locate the battery door.
  3. Fujifilm Endeavor 100ix Power Button Replacement: 3 단계, 이미지 1/1
    • Locate the latch on the battery door marked by the word "BATT." Use your finger to pry it open.
  4. Fujifilm Endeavor 100ix Power Button Replacement: 4 단계, 이미지 1/1
    • Remove the battery from the camera by pulling the battery door outwards.
  5. Fujifilm Endeavor 100ix Power Button Replacement: 5 단계, 이미지 1/1
    • Locate and remove three black 3.80mm screws on the back of the camera with the Phillips #00 screwdriver.
  6. Fujifilm Endeavor 100ix Power Button Replacement: 6 단계, 이미지 1/2 Fujifilm Endeavor 100ix Power Button Replacement: 6 단계, 이미지 2/2
    • Locate and remove the 6.4mm screws located on either side of the camera with a Phillips #00 screwdriver.
  7. Fujifilm Endeavor 100ix Power Button Replacement: 7 단계, 이미지 1/1
    • Locate the film door latch located on the side of the camera.
    • Insert the spudger under the latch.
    • Caution: Be careful during the following step in order to not break any parts within the camera. Prying the latch in any other direction than perpendicular may result in broken parts.
    • Pry the latch upward, applying force perpendicular to the camera.
  8. Fujifilm Endeavor 100ix Power Button Replacement: 8 단계, 이미지 1/1
    • Insert the flat edge of the spudger between the gold front casing and the black back casing.
    • Pry the spudger upward until the black back casing snaps out and is dislodged on that edge of the camera.
  9. Fujifilm Endeavor 100ix Power Button Replacement: 9 단계, 이미지 1/1
    • Squeeze the camera by placing a thumb on the tab marked CE.
    • Pull the back half of the camera firmly away from the camera body.
  10. Fujifilm Endeavor 100ix Power Button Replacement: 10 단계, 이미지 1/1
    • Locate and remove the 3.80mm screw inside the film compartment with the Phillips #00 screwdriver.
  11. Fujifilm Endeavor 100ix Power Button Replacement: 11 단계, 이미지 1/2 Fujifilm Endeavor 100ix Power Button Replacement: 11 단계, 이미지 2/2
    • Pull the front cover off of the camera by lifting the tripod tab over the tripod hole.
  12. Fujifilm Endeavor 100ix Power Button Replacement, Power Button: 12 단계, 이미지 1/1
    • Look on the inside of the black back casing.
    • Locate the red, rubber power button.
  13. Fujifilm Endeavor 100ix Power Button Replacement: 13 단계, 이미지 1/1
    • Using the tweezers, grab the red, rubber power button and pull it off the casing.
    • Discard the faulty power button.
    • Grab the new power button with the tweezers.
    • Put the power button into place by placing it where the old button was.
결론
To reassemble your device, follow the instructions from the "Disassembling Fujifilm Endeavor 100ix Outer Casing" guide in reverse order.
Eric Nicolai
회원 가입일: 01/10/11
679 평판
안내서 6개 작성하였습니다
Cal Poly, Team 13-5, Forte Winter 2011 Cal Poly, Team 13-5, Forte Winter 2011 회원
CPSU-FORTE-W11S13G5
5 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 1,696
