주요 콘텐츠로 건너뛰기
Fujifilm Fine S1800 LCD Screen Replacement
필요한 것
  1. Fujifilm Fine S1800 LCD Screen Replacement, Back Cover Assembly: 1 단계, 이미지 1/1
    • Unscrew the four 4mm screws on the left-hand side of the camera with the JIS #1 screwdriver.
  2. Fujifilm Fine S1800 LCD Screen Replacement: 2 단계, 이미지 1/1
    • Unscrew the four 4mm screws on the right-hand side of the camera with the JIS #1 screwdriver.
  3. Fujifilm Fine S1800 LCD Screen Replacement: 3 단계, 이미지 1/1
    • Unscrew the three 4mm screws on the bottom of the camera with the JIS #1 screwdriver.
  4. Fujifilm Fine S1800 LCD Screen Replacement: 4 단계, 이미지 1/2 Fujifilm Fine S1800 LCD Screen Replacement: 4 단계, 이미지 2/2
    • Take the plastic opening tool and place it in the space between the top of the screen and the top of the camera.
    • The cover will pop out.
    • You may have to work the back cover from different sides to get it to pop off.
  5. Fujifilm Fine S1800 LCD Screen Replacement, LCD Screen: 5 단계, 이미지 1/2 Fujifilm Fine S1800 LCD Screen Replacement, LCD Screen: 5 단계, 이미지 2/2
    • Remove the three 2 mm screws from the back cover plate with the Phillips #000 screwdriver.
    • Gently lift the back cover away from the device.
    • Do not pull or yank free. The LCD screen is connected to the motherboard via a small ribbon cable.
  6. Fujifilm Fine S1800 LCD Screen Replacement: 6 단계, 이미지 1/1
    • Move the lever to disconnect the ribbon cable from the circuit board.
    • Do not rip the fragile micro ribbon cable.
  7. Fujifilm Fine S1800 LCD Screen Replacement: 7 단계, 이미지 1/1
    • Gently remove the LCD screen.
    • Do not touch the screen directly.
결론
Ryan Rockford
회원 가입일: 02/15/17
618 평판
안내서 5개 작성하였습니다
USF Tampa, Team 8-6, Eyestone Spring 2017 USF Tampa, Team 8-6, Eyestone Spring 2017 회원
USFT-EYESTONE-S17S8G6
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 19
전체 시간: 556
