주요 콘텐츠로 건너뛰기
Fujifilm FinePix 4700 Zoom Back Cover Replacement
필요한 것
  1. Fujifilm FinePix 4700 Zoom Back Cover Replacement, Back Cover: 1 단계, 이미지 1/3 Fujifilm FinePix 4700 Zoom Back Cover Replacement, Back Cover: 1 단계, 이미지 2/3 Fujifilm FinePix 4700 Zoom Back Cover Replacement, Back Cover: 1 단계, 이미지 3/3
    • Use the Phillips #00 screwdriver to remove the 7 screws on the sides of the camera:
    • Four 3.95mm Phillips screws located on the bottom of the camera
    • Two 3.95mm Phillips screws located on the right side of the camera
    • One 3.95mm Phillips screw located on the left side of the camera
  2. Fujifilm FinePix 4700 Zoom Back Cover Replacement: 2 단계, 이미지 1/1
    • Slide open the battery compartment cover with your thumb.
  3. Fujifilm FinePix 4700 Zoom Back Cover Replacement: 3 단계, 이미지 1/3 Fujifilm FinePix 4700 Zoom Back Cover Replacement: 3 단계, 이미지 2/3 Fujifilm FinePix 4700 Zoom Back Cover Replacement: 3 단계, 이미지 3/3
    • Wedge the edge of the spudger between the front and back case, near the corner of the flash.
    • Carefully run the spudger along the right edge of the camera, creating an opening.
    • Insert the spudger into the left side of the camera, above the screwhole. Then carefully run it along this edge.
  4. Fujifilm FinePix 4700 Zoom Back Cover Replacement: 4 단계, 이미지 1/2 Fujifilm FinePix 4700 Zoom Back Cover Replacement: 4 단계, 이미지 2/2
    • Watch out for the orange ribbon that is still attached to the back cover when you lift it up. It is very delicate and might rip.
    • Slowly lift the back cover straight up, lightly jiggling it if necessary.
    • Remove the battery compartment cover.
  5. Fujifilm FinePix 4700 Zoom Back Cover Replacement: 5 단계, 이미지 1/1
    • Gently insert the spudger under the clip holding the orange ribbon. The clip should lift up and the ribbon will slide out.
    • This step will free the back cover from the rest of the camera.
결론
Sarthak Patel
회원 가입일: 04/03/12
10 평판
안내서 2개 작성하였습니다
Cal Poly, Team 14-8, Forte Spring 2012 Cal Poly, Team 14-8, Forte Spring 2012 회원
CPSU-FORTE-S12S14G8
5 회원들
안내서 17개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 1,191
