필요한 것
Use the Phillips #00 screwdriver to remove the 7 screws on the sides of the camera:
Four 3.95mm Phillips screws located on the bottom of the camera
Two 3.95mm Phillips screws located on the right side of the camera
One 3.95mm Phillips screw located on the left side of the camera
Use the tweezers to grab the speaker (located on left side of the camera) and pull straight up.
Use the spudger to push in the white tab on the square circuit board attached to the front case.
Use your finger to pull back the black plastic mount on the right side of the circuit board.
While holding back the black plastic mount, use the tweezers to gently lift the ribbon attached to the circuit board.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Hello! Great guide, congratulations indeed! Could you tell me where to find the orange ribbons to replace them? Thanks!
