주요 콘텐츠로 건너뛰기
Fujifilm FinePix A350 Battery Contact Replacement
필요한 것
  1. Fujifilm FinePix A350 Battery Contact Replacement, Batteries: 1 단계, 이미지 1/3 Fujifilm FinePix A350 Battery Contact Replacement, Batteries: 1 단계, 이미지 2/3 Fujifilm FinePix A350 Battery Contact Replacement, Batteries: 1 단계, 이미지 3/3
    • Locate the battery hatch on the bottom side of the camera, opposite the side with the power button.
    • Using your thumb, slide the hatch away from the center of the camera.
    • Flip the hatch toward yourself to open it. The batteries are spring-loaded; once the hatch is open, they will protrude far enough to be removed by hand.
  2. Fujifilm FinePix A350 Battery Contact Replacement, Battery Contact: 2 단계, 이미지 1/3 Fujifilm FinePix A350 Battery Contact Replacement, Battery Contact: 2 단계, 이미지 2/3 Fujifilm FinePix A350 Battery Contact Replacement, Battery Contact: 2 단계, 이미지 3/3
    • On the underside of the battery hatch, locate the single 3.0 mm screw connecting the battery contact to the hatch. Remove it using a Phillips screwdriver with a #0 bit.
    • Lift the contact from the end where the screw was located and pull away from the hatch to remove it.
결론
Jaxon Cramer
회원 가입일: 03/21/16
1,045 평판
안내서 9개 작성하였습니다
Clemson, Team 6-4, Benson Spring 2016 Clemson, Team 6-4, Benson Spring 2016 회원
CLEM-BENSON-S16S6G4
4 회원들
안내서 17개 작성하였습니다
댓글 한 개
It turned on after lifting up contact. Thank you, but we figured it out as I started to begin reading.
David Justin Laylon - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 24
전체 시간: 493
