주요 콘텐츠로 건너뛰기
Fujifilm FinePix A350 Memory Card Replacement
  1. Fujifilm FinePix A350 Memory Card Replacement, Batteries: 1 단계, 이미지 1/3 Fujifilm FinePix A350 Memory Card Replacement, Batteries: 1 단계, 이미지 2/3 Fujifilm FinePix A350 Memory Card Replacement, Batteries: 1 단계, 이미지 3/3
    • Locate the battery hatch on the bottom side of the camera, opposite the side with the power button.
    • Using your thumb, slide the hatch away from the center of the camera.
    • Flip the hatch toward yourself to open it. The batteries are spring-loaded; once the hatch is open, they will protrude far enough to be removed by hand.
  2. Fujifilm FinePix A350 Memory Card Replacement, Memory Card: 2 단계, 이미지 1/3 Fujifilm FinePix A350 Memory Card Replacement, Memory Card: 2 단계, 이미지 2/3 Fujifilm FinePix A350 Memory Card Replacement, Memory Card: 2 단계, 이미지 3/3
    • Locate the memory card in the long, thin slot above the battery compartment.
    • Using your thumb, push the memory card farther into the camera.
    • The memory card is spring-loaded and will pop out of the camera far enough to be removed by hand.
결론
Jaxon Cramer
회원 가입일: 03/21/16
1,045 평판
안내서 9개 작성하였습니다
Clemson, Team 6-4, Benson Spring 2016 Clemson, Team 6-4, Benson Spring 2016 회원
CLEM-BENSON-S16S6G4
4 회원들
안내서 17개 작성하였습니다
댓글 한 개
Bonjour monsieur,
Pourquoi je ‘arrive plus à voir les photos je peu les prendre mais pas les voir “erreurs écriture “
Carte sd vierge.
Merci pour votre aide et bonne soirée
oli.ber - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 19
30일 전: 70
전체 시간: 1,189
