주요 콘텐츠로 건너뛰기
Fujifilm FinePix AX665 Lens Housing Replacement
필요한 것
  1. Fujifilm FinePix AX665 Lens Housing Replacement, Lens Housing: 1 단계, 이미지 1/3 Fujifilm FinePix AX665 Lens Housing Replacement, Lens Housing: 1 단계, 이미지 2/3 Fujifilm FinePix AX665 Lens Housing Replacement, Lens Housing: 1 단계, 이미지 3/3
    • Use a #00 Phillips screwdriver to remove all six screws around the camera that is holding the case.
  2. Fujifilm FinePix AX665 Lens Housing Replacement: 2 단계, 이미지 1/3 Fujifilm FinePix AX665 Lens Housing Replacement: 2 단계, 이미지 2/3 Fujifilm FinePix AX665 Lens Housing Replacement: 2 단계, 이미지 3/3
    • Use a plastic pick to separate each side of the camera case apart.
  3. Fujifilm FinePix AX665 Lens Housing Replacement: 3 단계, 이미지 1/2 Fujifilm FinePix AX665 Lens Housing Replacement: 3 단계, 이미지 2/2
    • Remove the ribbon cable from the side of the logic board.
  4. Fujifilm FinePix AX665 Lens Housing Replacement: 4 단계, 이미지 1/2 Fujifilm FinePix AX665 Lens Housing Replacement: 4 단계, 이미지 2/2
    • Remove the four metal clips around the camera until you can feel the metal bracket that holds the screen pop off.
  5. Fujifilm FinePix AX665 Lens Housing Replacement: 5 단계, 이미지 1/2 Fujifilm FinePix AX665 Lens Housing Replacement: 5 단계, 이미지 2/2
    • Carefully flip the screen and remove the ribbon cable attaching it to the logic board.
  6. Fujifilm FinePix AX665 Lens Housing Replacement: 6 단계, 이미지 1/1
    • Remove the three screws holding the sensor.
  7. Fujifilm FinePix AX665 Lens Housing Replacement: 7 단계, 이미지 1/1
    • Remove the sensor ribbon cable from the logic board.
  8. Fujifilm FinePix AX665 Lens Housing Replacement: 8 단계, 이미지 1/1
    • Remove the lens housing ribbon cable.
  9. Fujifilm FinePix AX665 Lens Housing Replacement: 9 단계, 이미지 1/1
    • Remove the lens housing by moving the gray clip holding the unit.
결론
Zheng Xu
회원 가입일: 09/18/19
771 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 17
전체 시간: 325
