주요 콘텐츠로 건너뛰기
Fujifilm FinePix F505EXR Battery Replacement
필요한 것
  1. Fujifilm FinePix F505EXR Battery Replacement, Battery: 1 단계, 이미지 1/2 Fujifilm FinePix F505EXR Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Power the device down before taking any other actions.
    • Hold the camera with the lens facing towards youself.
    • Turn the camera upside down and place your right thumb on the battery chamber cover.
  2. Fujifilm FinePix F505EXR Battery Replacement: 2 단계, 이미지 1/2 Fujifilm FinePix F505EXR Battery Replacement: 2 단계, 이미지 2/2
    • Hold the camera, then pull the battery chamber towards yourself with your right thumb.
    • Pull the cover entirely out and release it to reveal the battery.
  3. Fujifilm FinePix F505EXR Battery Replacement: 3 단계, 이미지 1/2 Fujifilm FinePix F505EXR Battery Replacement: 3 단계, 이미지 2/2
    • Locate the orange battery latch that holds the battery in place.
    • Use your finger to push the latch away from yourself to release the battery.
    • Remove the battery manually from the battery chamber.
    • Place the battery into a charger if it is dead.
    • Remove battery before performing any other repairs.
    • Replace defective battery if previous steps fail
    • Contact support on the Fujifilm website for further assistance
결론
Matthew Kilmonis
회원 가입일: 03/08/17
219 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S2-G6, Isaacson Spring 2017 UMass Dartmouth, Team S2-G6, Isaacson Spring 2017 회원
UMASSD-ISAACSON-S17S2G6
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 13
전체 시간: 987
