주요 콘텐츠로 건너뛰기
Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement
필요한 것
  1. Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement, Battery: 1 단계, 이미지 1/2 Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement, Battery: 1 단계, 이미지 2/2
    • Power the device down before taking any other actions.
    • Hold the camera with the lens facing towards youself.
    • Turn the camera upside down and place your right thumb on the battery chamber cover.
  2. Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement: 2 단계, 이미지 1/2 Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement: 2 단계, 이미지 2/2
    • Hold the camera, then pull the battery chamber towards yourself with your right thumb.
    • Pull the cover entirely out and release it to reveal the battery.
  3. Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement: 3 단계, 이미지 1/2 Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement: 3 단계, 이미지 2/2
    • Locate the orange battery latch that holds the battery in place.
    • Use your finger to push the latch away from yourself to release the battery.
    • Remove the battery manually from the battery chamber.
    • Place the battery into a charger if it is dead.
    • Remove battery before performing any other repairs.
    • Replace defective battery if previous steps fail
    • Contact support on the Fujifilm website for further assistance
  4. Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement, Selector Button Circuit Board: 5 단계, 이미지 1/3 Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement, Selector Button Circuit Board: 5 단계, 이미지 2/3 Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement, Selector Button Circuit Board: 5 단계, 이미지 3/3
    • Remove four 2.5mm Phillips #1 screws on the bottom of the camera near where the camera mount attaches.
    • Remove two 5.1mm Phillips #1 screws on the left side of the camera relative to the LCD screen.
    • Remove two 5.1mm Phillips #1 screws on the right side of the camera relative to the LCD screen nearest to the mode wheel.
  5. Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement: 6 단계, 이미지 1/2 Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Place the camera lens face down with the LCD screen face up on a flat surface, or hold it. Carefully lift the camera’s back cover approximately 1 inch.
    • Carefully lift the ribbon clamp connector back using the tweezers and remove the blue ribbon.
    • Do NOT pull on ribbon if the ribbon clamp connector still grasps the blue ribbon. This could cause severe damage to the ribbon.
    • If you are replacing the LCD monitor you can skip steps 6 and 7 for the selector button circuit board guide and go directly to the LCD monitor repair guide.
    • If you are replacing the Mode Dial you can skip steps 6 and 7 for the selector button circuit board guide and go directly to the Mode Dial repair guide.
  6. Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement: 7 단계, 이미지 1/1
    • Remove the back of the camera case and place it on a flat surface with the selector button circuit board facing up.
    • Remove the three 3.5mm Phillips #1 screws located on the chip seen in the image.
  7. Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement: 8 단계, 이미지 1/3 Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement: 8 단계, 이미지 2/3 Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement: 8 단계, 이미지 3/3
    • Lift the chip with tweezers to remove it from the other remaining components.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Matthew Kilmonis
회원 가입일: 03/08/17
219 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S2-G6, Isaacson Spring 2017 UMass Dartmouth, Team S2-G6, Isaacson Spring 2017 회원
UMASSD-ISAACSON-S17S2G6
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 250
