주요 콘텐츠로 건너뛰기
Fujifilm FinePix HS30EXR Battery Replacement
필요한 것
  1. Fujifilm FinePix HS30EXR Battery Replacement, Battery: 1 단계, 이미지 1/1
    • To gain access to the battery, flip the camera so that is upside down.
    • Pull on the lever while at the same time pulling outwards, away from the device.
  2. Fujifilm FinePix HS30EXR Battery Replacement: 2 단계, 이미지 1/1
    • Open the battery compartment.
    • Pull the grey lever towards the device; this should dislodge the battery from the compartment.
  3. Fujifilm FinePix HS30EXR Battery Replacement: 3 단계, 이미지 1/1
    • Pull the battery out of the compartment, and replace it with a newly functional battery.
결론
Andrew Scouten
회원 가입일: 10/22/18
838 평판
안내서 5개 작성하였습니다
Baylor, Team S1-G2, Williams Fall 2018 Baylor, Team S1-G2, Williams Fall 2018 회원
BU-WILLIAMS-F18S1G2
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 15
전체 시간: 755
