주요 콘텐츠로 건너뛰기
Fujifilm FinePix HS30EXR Lens Replacement
필요한 것
  1. Fujifilm FinePix HS30EXR Lens Replacement, Frame: 1 단계, 이미지 1/1
    • Flip the camera so that the bottom is facing upwards.
    • With the Phillips #00 screwdriver, remove all four screws.
  2. Fujifilm FinePix HS30EXR Lens Replacement: 2 단계, 이미지 1/1
    • Flip the camera so that it is now on the right side.
  3. Fujifilm FinePix HS30EXR Lens Replacement: 3 단계, 이미지 1/1
    • Flip the camera so that it is now on the left side.
    • Move or remove the flap hiding the camera ports.
    • With the Phillips #00 screwdriver, remove all screws.
  4. Fujifilm FinePix HS30EXR Lens Replacement: 4 단계, 이미지 1/1
    • Flip the camera so that it is now on the top side.
    • With a spudger, pry off the highlighted metal piece of the camera.
  5. Fujifilm FinePix HS30EXR Lens Replacement: 5 단계, 이미지 1/1
  6. Fujifilm FinePix HS30EXR Lens Replacement: 6 단계, 이미지 1/1
    • Pull the LCD screen up and out of the way.
    • With the Phillips #00 screwdriver, remove the screws.
  7. Fujifilm FinePix HS30EXR Lens Replacement: 7 단계, 이미지 1/2 Fujifilm FinePix HS30EXR Lens Replacement: 7 단계, 이미지 2/2
    • With a spudger, pry off the frame.
    • If the frame does not easily dislodge after a few attempts, ensure that all screws are taken out.
  8. Fujifilm FinePix HS30EXR Lens Replacement, Motherboard: 8 단계, 이미지 1/1
    • Slowly and carefully pull the frame away to have a better view of the inside.
  9. Fujifilm FinePix HS30EXR Lens Replacement: 9 단계, 이미지 1/1
    • Peel back (or off) the black tape to expose more of the inside of the camera.
    • Flip the white switch of the highlighted chamber up, and that should unlock the ribbon cable from its compartment.
    • To see if this worked, gently pull the ribbon cable out of the compartment. It should come out without force.
  10. Fujifilm FinePix HS30EXR Lens Replacement: 10 단계, 이미지 1/1
    • Disconnect the ribbon cable.
  11. Fujifilm FinePix HS30EXR Lens Replacement: 11 단계, 이미지 1/1
    • With the Phillips #00 screwdriver, remove all five screws.
    • Remove the metal casing.
  12. Fujifilm FinePix HS30EXR Lens Replacement: 12 단계, 이미지 1/1
  13. Fujifilm FinePix HS30EXR Lens Replacement: 13 단계, 이미지 1/1
    • Ensure the four ribbon cables are disconnected from the motherboard.
    • Be aware, one is under the black tape.
  14. Fujifilm FinePix HS30EXR Lens Replacement: 14 단계, 이미지 1/1
    • Begin desoldering all four highlighted areas.
  15. Fujifilm FinePix HS30EXR Lens Replacement: 15 단계, 이미지 1/1
    • Remove the motherboard.
  16. Fujifilm FinePix HS30EXR Lens Replacement, Lens: 16 단계, 이미지 1/1
    • Once the motherboard is taken out, with a screwdriver, unscrew all highlighted screws.
    • Take the lens off once it is unscrewed.
  17. Fujifilm FinePix HS30EXR Lens Replacement: 17 단계, 이미지 1/1
    • Un-attatch the current lens, and replace it with the new lens.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Andrew Scouten
회원 가입일: 10/22/18
838 평판
안내서 5개 작성하였습니다
Baylor, Team S1-G2, Williams Fall 2018 Baylor, Team S1-G2, Williams Fall 2018 회원
BU-WILLIAMS-F18S1G2
4 회원들
안내서 12개 작성하였습니다
댓글 한 개
What is the price for Normal lens for Fujifilm HS30EXR?
khadgarai286 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 76
전체 시간: 4,538
