이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Flip the camera so that the bottom is facing upwards.
With the Phillips #00 screwdriver, remove all four screws.
Flip the camera so that it is now on the right side.
Flip the camera so that it is now on the left side.
Move or remove the flap hiding the camera ports.
With the Phillips #00 screwdriver, remove all screws.
Flip the camera so that it is now on the top side.
With a spudger, pry off the highlighted metal piece of the camera.
Pull the LCD screen up and out of the way.
With the Phillips #00 screwdriver, remove the screws.
Slowly and carefully pull the frame away to have a better view of the inside.
Peel back (or off) the black tape to expose more of the inside of the camera.
Flip the white switch of the highlighted chamber up, and that should unlock the ribbon cable from its compartment.
With the Phillips #00 screwdriver, remove all five screws.
Remove the metal casing.
Once the motherboard is taken out, with a screwdriver, unscrew all highlighted screws.
Take the lens off once it is unscrewed.
다른 3명이 해당 안내서를 완성하였습니다.
