주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Fujifilm FinePix HS30EXR Screen Replacement
필요한 것
  1. Fujifilm FinePix HS30EXR Screen Replacement, Frame: 1 단계, 이미지 1/1
    • Flip the camera so that the bottom is facing upwards.
    • With the Phillips #00 screwdriver, remove all four screws.
  2. Fujifilm FinePix HS30EXR Screen Replacement: 2 단계, 이미지 1/1
    • Flip the camera so that it is now on the right side.
  3. Fujifilm FinePix HS30EXR Screen Replacement: 3 단계, 이미지 1/1
    • Flip the camera so that it is now on the left side.
    • Move or remove the flap hiding the camera ports.
    • With the Phillips #00 screwdriver, remove all screws.
  4. Fujifilm FinePix HS30EXR Screen Replacement: 4 단계, 이미지 1/1
    • Flip the camera so that it is now on the top side.
    • With a spudger, pry off the highlighted metal piece of the camera.
  5. Fujifilm FinePix HS30EXR Screen Replacement: 5 단계, 이미지 1/1
  6. Fujifilm FinePix HS30EXR Screen Replacement: 6 단계, 이미지 1/1
    • Pull the LCD screen up and out of the way.
    • With the Phillips #00 screwdriver, remove the screws.
  7. Fujifilm FinePix HS30EXR Screen Replacement: 7 단계, 이미지 1/2 Fujifilm FinePix HS30EXR Screen Replacement: 7 단계, 이미지 2/2
    • With a spudger, pry off the frame.
    • If the frame does not easily dislodge after a few attempts, ensure that all screws are taken out.
  8. Fujifilm FinePix HS30EXR Screen Replacement, Screen: 8 단계, 이미지 1/1
    • Slowly and carefully pull the frame away to have a better view of the inside.
  9. Fujifilm FinePix HS30EXR Screen Replacement: 9 단계, 이미지 1/1
    • Peel back (or off) the black tape to expose more of the inside of the camera.
    • Flip the white switch of the highlighted chamber up, and that should unlock the ribbon cable from its compartment.
    • To see if this worked, gently pull the ribbon cable out of the compartment. It should come out without force.
  10. Fujifilm FinePix HS30EXR Screen Replacement: 10 단계, 이미지 1/1
    • Now that the ribbon cable is unconnected, pull away the frame to work on.
  11. Fujifilm FinePix HS30EXR Screen Replacement: 11 단계, 이미지 1/1
    • Flip the frame component so that the inside is now accessible.
    • With a screwdriver, unscrew all highlighted screws.
  12. Fujifilm FinePix HS30EXR Screen Replacement: 12 단계, 이미지 1/1
    • Flip the LCD Screen component so that the bottom half is now accessible.
  13. Fujifilm FinePix HS30EXR Screen Replacement: 13 단계, 이미지 1/1
    • Remove the LCD Screen component from its mount.
    • Turn the LCD Screen component so that the right side is now accessible.
  14. Fujifilm FinePix HS30EXR Screen Replacement: 14 단계, 이미지 1/1
    • The LCD Screen can now be removed from the LCD Screen Mount.
    • Carefully remove the LCD Screen, as it is attached by another ribbon cable.
  15. Fujifilm FinePix HS30EXR Screen Replacement: 15 단계, 이미지 1/1
    • To remove the LCD Screen, flip the switch on the ribbon cable's container that is closest to the ribbon cable (highlighted by the red circle).
    • Carefully remove the ribbon cable from its compartment, and remove the LCD Screen.
    • Position your new LCD Screen onto where the old one was removed from, and reattach the ribbon cable (ensure that the switch is now clamped down; a light tug should not dislodge the ribbon cable).
결론
다른 3명이 해당 안내서를 완성하였습니다.
Andrew Scouten
회원 가입일: 10/22/18
796 평판
안내서 5개 작성하였습니다
Baylor, Team S1-G2, Williams Fall 2018 Baylor, Team S1-G2, Williams Fall 2018 회원
BU-WILLIAMS-F18S1G2
4 회원들
안내서 12개 작성하였습니다
댓글 한 개
Ecran de rechange trouvé chez elecok.
Tuto testé, fonctionne aussi pour le Fuji HS20 EXR.
Bravo et Merci à Andrew et aux contributeurs
Bernard MRT - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 32
전체 시간: 2,471
