주요 콘텐츠로 건너뛰기
Fujifilm FinePix S1 EVF/LCD Button Replacement
필요한 것
  1. Fujifilm FinePix S1 EVF/LCD Button Replacement, Back Camera Body: 1 단계, 이미지 1/3 Fujifilm FinePix S1 EVF/LCD Button Replacement, Back Camera Body: 1 단계, 이미지 2/3 Fujifilm FinePix S1 EVF/LCD Button Replacement, Back Camera Body: 1 단계, 이미지 3/3
    • Remove the 7 screws on the perimeter of the camera body.
  2. Fujifilm FinePix S1 EVF/LCD Button Replacement: 2 단계, 이미지 1/3 Fujifilm FinePix S1 EVF/LCD Button Replacement: 2 단계, 이미지 2/3 Fujifilm FinePix S1 EVF/LCD Button Replacement: 2 단계, 이미지 3/3
    • Remove the flash accessory cap.
    • Remove the spacer covering the screws under the flash accessory cap.
  3. Fujifilm FinePix S1 EVF/LCD Button Replacement: 3 단계, 이미지 1/3 Fujifilm FinePix S1 EVF/LCD Button Replacement: 3 단계, 이미지 2/3 Fujifilm FinePix S1 EVF/LCD Button Replacement: 3 단계, 이미지 3/3
    • Remove the 4 screws from the inside of the flash accessory slot.
    • Pull off the flash accessory slot.
  4. Fujifilm FinePix S1 EVF/LCD Button Replacement: 4 단계, 이미지 1/2 Fujifilm FinePix S1 EVF/LCD Button Replacement: 4 단계, 이미지 2/2
    • Remove the screw from LCD Screen hinge cover.
    • Remove the LCD Screen hinge cover.
  5. Fujifilm FinePix S1 EVF/LCD Button Replacement: 5 단계, 이미지 1/3 Fujifilm FinePix S1 EVF/LCD Button Replacement: 5 단계, 이미지 2/3 Fujifilm FinePix S1 EVF/LCD Button Replacement: 5 단계, 이미지 3/3
    • Remove the 3 screws located on the LCD screen hinge.
    • Remove the caps from both ends of the LCD screen hinge by lifting them off.
  6. Fujifilm FinePix S1 EVF/LCD Button Replacement: 6 단계, 이미지 1/1
    • Remove the 2 screws from under the LCD hinge caps.
  7. Fujifilm FinePix S1 EVF/LCD Button Replacement: 7 단계, 이미지 1/3 Fujifilm FinePix S1 EVF/LCD Button Replacement: 7 단계, 이미지 2/3 Fujifilm FinePix S1 EVF/LCD Button Replacement: 7 단계, 이미지 3/3
    • Pry apart the back body from the rest of the camera.
  8. Fujifilm FinePix S1 EVF/LCD Button Replacement: 8 단계, 이미지 1/2 Fujifilm FinePix S1 EVF/LCD Button Replacement: 8 단계, 이미지 2/2
    • Carefully pull the back body off of the camera.
    • Make sure to not yank off the connections from the body to the motherboard.
  9. Fujifilm FinePix S1 EVF/LCD Button Replacement: 9 단계, 이미지 1/3 Fujifilm FinePix S1 EVF/LCD Button Replacement: 9 단계, 이미지 2/3 Fujifilm FinePix S1 EVF/LCD Button Replacement: 9 단계, 이미지 3/3
    • Use a spudger to lift up on the tab, releasing the yellow wire strip.
    • Use a spudger to lift up on the side tab, releasing the blue wire connection.
  10. Fujifilm FinePix S1 EVF/LCD Button Replacement, EVF/LCD Button Cover: 10 단계, 이미지 1/1
    • Remove 2 screws from back of EVF/LCD button.
  11. Fujifilm FinePix S1 EVF/LCD Button Replacement: 11 단계, 이미지 1/3 Fujifilm FinePix S1 EVF/LCD Button Replacement: 11 단계, 이미지 2/3 Fujifilm FinePix S1 EVF/LCD Button Replacement: 11 단계, 이미지 3/3
    • Pull EVF/LCD button frame out from the camera casing.
  12. Fujifilm FinePix S1 EVF/LCD Button Replacement: 12 단계, 이미지 1/3 Fujifilm FinePix S1 EVF/LCD Button Replacement: 12 단계, 이미지 2/3 Fujifilm FinePix S1 EVF/LCD Button Replacement: 12 단계, 이미지 3/3
    • Pull button cover off of the button frame.
결론
Brandon Benavente
회원 가입일: 02/15/16
677 평판
안내서 6개 작성하였습니다
USF Tampa, Team 3-6, Sullivan Spring 2016 USF Tampa, Team 3-6, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S3G6
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 6
30일 전: 17
전체 시간: 1,069
