주요 콘텐츠로 건너뛰기
Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement
필요한 것
  1. Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement, LCD Screen: 1 단계, 이미지 1/3 Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement, LCD Screen: 1 단계, 이미지 2/3 Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement, LCD Screen: 1 단계, 이미지 3/3
    • Use a PH0 screwdriver to remove four screws on the right side, three screws on the bottom, and four on the left side to take off the rear plate.
  2. Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement: 2 단계, 이미지 1/3 Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement: 2 단계, 이미지 2/3 Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement: 2 단계, 이미지 3/3
    • Remove the three screws holding the LCD screen in place.
    • Replace with new screen.
  3. Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement, Flash Mechanism Latch Spring: 3 단계, 이미지 1/3 Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement, Flash Mechanism Latch Spring: 3 단계, 이미지 2/3 Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement, Flash Mechanism Latch Spring: 3 단계, 이미지 3/3
    • Remove the two screws from underneath the flash mechanism.
    • Remove the two screws placed on the right and left sides of the camera.
  4. Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement: 4 단계, 이미지 1/1
    • Pry the top of the camera off using the given tool
  5. Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement: 5 단계, 이미지 1/1
    • Remove two silver plated screw from under the top of the camera, under the flash.
  6. Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement: 6 단계, 이미지 1/1
    • Remove the rectangular plastic piece.
  7. Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement: 7 단계, 이미지 1/1
    • Insert new spring.
    • Replace the plastic piece.
결론
Megan Merlo
회원 가입일: 03/24/15
78 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 4-2, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-2, Vijaybhaskar Spring 2015 회원
UMASSD-VIJAYBHASKAR-S15S4G2
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 1,124
