주요 콘텐츠로 건너뛰기
Fujifilm FinePix S2980 Speaker Replacement
필요한 것
  1. Fujifilm FinePix S2980 Speaker Replacement, LCD Screen: 1 단계, 이미지 1/3 Fujifilm FinePix S2980 Speaker Replacement, LCD Screen: 1 단계, 이미지 2/3 Fujifilm FinePix S2980 Speaker Replacement, LCD Screen: 1 단계, 이미지 3/3
    • Use a PH0 screwdriver to remove four screws on the right side, three screws on the bottom, and four on the left side to take off the rear plate.
  2. Fujifilm FinePix S2980 Speaker Replacement: 2 단계, 이미지 1/3 Fujifilm FinePix S2980 Speaker Replacement: 2 단계, 이미지 2/3 Fujifilm FinePix S2980 Speaker Replacement: 2 단계, 이미지 3/3
    • Remove the three screws holding the LCD screen in place.
    • Replace with new screen.
  3. Fujifilm FinePix S2980 Speaker Replacement, Speaker: 3 단계, 이미지 1/3 Fujifilm FinePix S2980 Speaker Replacement, Speaker: 3 단계, 이미지 2/3 Fujifilm FinePix S2980 Speaker Replacement, Speaker: 3 단계, 이미지 3/3
    • Remove the two screws from underneath the flash mechanism.
    • Remove the two screws placed on the right and left sides of the camera.
  4. Fujifilm FinePix S2980 Speaker Replacement: 4 단계, 이미지 1/1
    • Use the opening tool to pry the top plate off of the top of the camera.
  5. Fujifilm FinePix S2980 Speaker Replacement: 5 단계, 이미지 1/2 Fujifilm FinePix S2980 Speaker Replacement: 5 단계, 이미지 2/2
    • Remove the four larger silver plated screws placed on the inside of the lens.
    • Remove the lens by lifting it up from the cavity.
  6. Fujifilm FinePix S2980 Speaker Replacement: 6 단계, 이미지 1/3 Fujifilm FinePix S2980 Speaker Replacement: 6 단계, 이미지 2/3 Fujifilm FinePix S2980 Speaker Replacement: 6 단계, 이미지 3/3
    • Remove the five bracket screws.
  7. Fujifilm FinePix S2980 Speaker Replacement: 7 단계, 이미지 1/2 Fujifilm FinePix S2980 Speaker Replacement: 7 단계, 이미지 2/2
    • Once the screws are out, remove the the bracket
    • Remove speaker with given tweezer tool and replace
결론
다른 2명이 해당 안내서를 완성하였습니다.
diane heidke
회원 가입일: 03/24/15
24 평판
안내서 1개 작성함
UMass Dartmouth, Team 4-2, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-2, Vijaybhaskar Spring 2015 회원
UMASSD-VIJAYBHASKAR-S15S4G2
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 1,067
