주요 콘텐츠로 건너뛰기
Fujifilm FinePix S4200 Lens Replacement
필요한 것
  1. Fujifilm FinePix S4200 Lens Replacement, Lens: 1 단계, 이미지 1/1
    • Turn off the camera by pushing the ON/OFF switch as shown.
  2. Fujifilm FinePix S4200 Lens Replacement: 2 단계, 이미지 1/3 Fujifilm FinePix S4200 Lens Replacement: 2 단계, 이미지 2/3 Fujifilm FinePix S4200 Lens Replacement: 2 단계, 이미지 3/3
    • Using a Phillips #000 screwdriver, remove all of the 4mm screws from the left, right, and bottom of the camera.
  3. Fujifilm FinePix S4200 Lens Replacement: 3 단계, 이미지 1/1
    • Remove casing part pictured by gently pulling up until casing is fully detached.
  4. Fujifilm FinePix S4200 Lens Replacement: 4 단계, 이미지 1/3 Fujifilm FinePix S4200 Lens Replacement: 4 단계, 이미지 2/3 Fujifilm FinePix S4200 Lens Replacement: 4 단계, 이미지 3/3
    • Remove the 4 mm screws on the metal plate. Then remove the 4 mm screws on left side of the camera, and remove the two 4mm screws on right side.
    • Use the Phillips #000 to avoid stripping the screws.
  5. Fujifilm FinePix S4200 Lens Replacement: 5 단계, 이미지 1/1
    • Remove orange ribbon cable by gently pulling on the cable until it is detached from the clamping device on the motherboard.
    • Remove the top casing by pulling upwards.
  6. Fujifilm FinePix S4200 Lens Replacement: 6 단계, 이미지 1/2 Fujifilm FinePix S4200 Lens Replacement: 6 단계, 이미지 2/2
    • Carefully remove the LCD screen.
    • Gently pull on orange tab until it is free. This orange strip is susceptible to tearing.
  7. Fujifilm FinePix S4200 Lens Replacement: 7 단계, 이미지 1/2 Fujifilm FinePix S4200 Lens Replacement: 7 단계, 이미지 2/2
    • Remove remaining 4mm screw. Detach metal plate by lifting plate upwards.
    • Use the Phillips #000 screwdriver.
  8. Fujifilm FinePix S4200 Lens Replacement: 8 단계, 이미지 1/1
    • Remove remaining orange tabs on motherboard by gently pulling on all tab until they are free.
    • Caution: Orange strips are susceptible to tearing.
  9. Fujifilm FinePix S4200 Lens Replacement: 9 단계, 이미지 1/1
    • Using the Phillips #000 screwdriver, remove the 4mm screws in the corners of the motherboard.
  10. Fujifilm FinePix S4200 Lens Replacement: 10 단계, 이미지 1/1
    • Use a soldering iron to desolder the five connections shown.
    • Caution: After removing the soldered connections, they must be given ample time to cool before moving to the next step.
  11. Fujifilm FinePix S4200 Lens Replacement: 11 단계, 이미지 1/1
    • Remove the motherboard. It should be free of all connections at this point and can be lifted with ease.
  12. Fujifilm FinePix S4200 Lens Replacement: 12 단계, 이미지 1/2 Fujifilm FinePix S4200 Lens Replacement: 12 단계, 이미지 2/2
    • Using a Phillips #000 screwdriver, remove the 4mm screws around the metal plate.
    • Using a Phillips #000 screwdriver, remove the 10mm screws.
  13. Fujifilm FinePix S4200 Lens Replacement: 13 단계, 이미지 1/1
    • Slowly lift up the metal plate and remove it from the camera.
  14. Fujifilm FinePix S4200 Lens Replacement: 14 단계, 이미지 1/1
    • Using a Phillips #000 screwdriver, remove the 10mm screw.
  15. Fujifilm FinePix S4200 Lens Replacement: 15 단계, 이미지 1/2 Fujifilm FinePix S4200 Lens Replacement: 15 단계, 이미지 2/2
    • Remove the inner lens.
    • Caution: Be careful while removing the lens.
  16. Fujifilm FinePix S4200 Lens Replacement: 16 단계, 이미지 1/1
    • Change the broken inner lens with a new inner lens.
    • Reassemble the camera.
결론
Joshua Greer
회원 가입일: 10/31/18
253 평판
안내서 1개 작성함
IUPUI, Team S1-G5, Harley Fall 2018 IUPUI, Team S1-G5, Harley Fall 2018 회원
IUPUI-HARLEY-F18S1G5
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 17
30일 전: 65
전체 시간: 2,593
