이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Using a Phillips #000 screwdriver, remove all of the 4mm screws from the left, right, and bottom of the camera.
Remove casing part pictured by gently pulling up until casing is fully detached.
Remove the 4 mm screws on the metal plate. Then remove the 4 mm screws on left side of the camera, and remove the two 4mm screws on right side.
Remove orange ribbon cable by gently pulling on the cable until it is detached from the clamping device on the motherboard.
Remove the top casing by pulling upwards.
Remove remaining 4mm screw. Detach metal plate by lifting plate upwards.
Remove remaining orange tabs on motherboard by gently pulling on all tab until they are free.
Using the Phillips #000 screwdriver, remove the 4mm screws in the corners of the motherboard.
Remove the motherboard. It should be free of all connections at this point and can be lifted with ease.
Using a Phillips #000 screwdriver, remove the 4mm screws around the metal plate.
Using a Phillips #000 screwdriver, remove the 10mm screws.
Change the broken inner lens with a new inner lens.
Reassemble the camera.
