주요 콘텐츠로 건너뛰기
Fujifilm FinePix S4200 Viewfinder Replacement
필요한 것
  1. Fujifilm FinePix S4200 Viewfinder  Replacement, LCD Screen: 1 단계, 이미지 1/1
    • Turn the camera off.
    • Turn the camera upside down so that the battery compartment is showing.
  2. Fujifilm FinePix S4200 Viewfinder  Replacement: 2 단계, 이미지 1/1
    • Remove the three 4 mm screws from the bottom of the camera with a Phillips #000 screwdriver.
  3. Fujifilm FinePix S4200 Viewfinder  Replacement: 3 단계, 이미지 1/1
    • Rotate camera to the side where the speaker ports are located.
    • Remove the three 4 mm screws with a Phillips #000 screwdriver.
  4. Fujifilm FinePix S4200 Viewfinder  Replacement: 4 단계, 이미지 1/1
    • Turn the camera to the opposite side where the HDMI port is located.
    • Remove all five 4 mm screws with a Phillips #000 screwdriver.
  5. Fujifilm FinePix S4200 Viewfinder  Replacement: 5 단계, 이미지 1/3 Fujifilm FinePix S4200 Viewfinder  Replacement: 5 단계, 이미지 2/3 Fujifilm FinePix S4200 Viewfinder  Replacement: 5 단계, 이미지 3/3
    • Casing is fragile.
    • Utilize the plastic opening tool to pry in between the back casing of the camera from the front casing.
    • Continue this motion around the camera to create a wedge between the front and back casing of the camera.
  6. Fujifilm FinePix S4200 Viewfinder  Replacement: 6 단계, 이미지 1/1
    • Use force to pull apart the back casing from the camera.
  7. Fujifilm FinePix S4200 Viewfinder  Replacement: 7 단계, 이미지 1/1
    • Remove the two 4 mm screws that hold the motherboard and metal plate in place.
  8. Fujifilm FinePix S4200 Viewfinder  Replacement: 8 단계, 이미지 1/2 Fujifilm FinePix S4200 Viewfinder  Replacement: 8 단계, 이미지 2/2
    • Utilize the plastic opening tool to gently lift the LCD screen away from the metal plate.
    • Flip over LCD screen so that the left side of the metal plate is visible.
  9. Fujifilm FinePix S4200 Viewfinder  Replacement: 9 단계, 이미지 1/1
    • Rotate the camera vertically so that it is easier to manage.
    • Use a Phillips #000 screwdriver to remove the two 4mm screws that are located on the metal plate under the LCD screen.
  10. Fujifilm FinePix S4200 Viewfinder  Replacement: 10 단계, 이미지 1/1
    • Detach the metal plate from the motherboard.
  11. Fujifilm FinePix S4200 Viewfinder  Replacement: 11 단계, 이미지 1/2 Fujifilm FinePix S4200 Viewfinder  Replacement: 11 단계, 이미지 2/2
    • The orange ribbon cable is fragile.
    • Pull back the small black latch connecting the orange ribbon cable to the motherboard.
    • Gently remove the LCD screen from the motherboard.
  12. Fujifilm FinePix S4200 Viewfinder  Replacement, Viewfinder: 12 단계, 이미지 1/2 Fujifilm FinePix S4200 Viewfinder  Replacement, Viewfinder: 12 단계, 이미지 2/2
    • Remove the two 4 mm screws with a Phillips 000 screwdriver under the viewfinder.
  13. Fujifilm FinePix S4200 Viewfinder  Replacement: 13 단계, 이미지 1/1
    • Carefully pull off the plastic cover from the view finder.
  14. Fujifilm FinePix S4200 Viewfinder  Replacement: 14 단계, 이미지 1/1
    • Remove the two 3mm screws surrounding the viewfinder with a Phillips 000 screwdriver.
  15. Fujifilm FinePix S4200 Viewfinder  Replacement: 15 단계, 이미지 1/1
    • Orange ribbon is fragile.
    • Using the plastic opening tool, pull down the small black latch to remove the orange ribbon from the mother board.
  16. Fujifilm FinePix S4200 Viewfinder  Replacement: 16 단계, 이미지 1/1
    • Pull the viewfinder up to remove it from the body of the camera
결론
다른 2명이 해당 안내서를 완성하였습니다.
Melissa Burciaga
회원 가입일: 09/14/15
152 평판
안내서 1개 작성함
CSU Fullerton, Team 1-4, Bruce Fall 2015 CSU Fullerton, Team 1-4, Bruce Fall 2015 회원
CSUF-BRUCE-F15S1G4
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 8
전체 시간: 899
