주요 콘텐츠로 건너뛰기
Fujifilm FinePix S4800 Battery Compartment Door Replacement
필요한 것
  1. Fujifilm FinePix S4800 Battery Compartment Door Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure that the camera is powered off before continuing.
    • Rotate the camera so that the label on the base of the camera is facing up.
    • On the battery compartment door, there is a slider that says "open". Slide it down and push the door to the right to release the door.
  2. Fujifilm FinePix S4800 Battery Compartment Door Replacement: 2 단계, 이미지 3개 중 1개 Fujifilm FinePix S4800 Battery Compartment Door Replacement: 2 단계, 이미지 3개 중 2개 Fujifilm FinePix S4800 Battery Compartment Door Replacement: 2 단계, 이미지 3개 중 3개
    • Remove all four batteries and set them aside.
    • When replacing the batteries, be sure to note the markings on the face of the battery compartment. These markings let you know which side of the battery ("+" or "-") needs to be facing up in each slot.
  3. Fujifilm FinePix S4800 Battery Compartment Door Replacement, Rear Case: 3 단계, 이미지 1개 중 1개
    • Remove the three 5.0 mm JIS #000 screws on the bottom of the camera.
  4. Fujifilm FinePix S4800 Battery Compartment Door Replacement: 4 단계, 이미지 1개 중 1개
    • Rotate the camera so that the HDMI port is facing up.
    • Remove the two 5.0 mm JIS #000 screws.
  5. Fujifilm FinePix S4800 Battery Compartment Door Replacement: 5 단계, 이미지 1개 중 1개
    • Rotate the camera so that the text "30x superwide 24-720mm" is facing up.
  6. Fujifilm FinePix S4800 Battery Compartment Door Replacement: 6 단계, 이미지 3개 중 1개 Fujifilm FinePix S4800 Battery Compartment Door Replacement: 6 단계, 이미지 3개 중 2개 Fujifilm FinePix S4800 Battery Compartment Door Replacement: 6 단계, 이미지 3개 중 3개
    • Press the pop-up button highlighted in the picture to release the flash mechanism.
    • Remove the two 5.0 mm JIS #000 screws highlighted in the picture.
  7. Fujifilm FinePix S4800 Battery Compartment Door Replacement: 7 단계, 이미지 3개 중 1개 Fujifilm FinePix S4800 Battery Compartment Door Replacement: 7 단계, 이미지 3개 중 2개 Fujifilm FinePix S4800 Battery Compartment Door Replacement: 7 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to separate the rear case from the camera on each of the sides until the panel is completely separated.
    • The plastic case is fragile, so take your time on each side making sure to pry each side evenly as you continue around the camera with the tool.
  8. Fujifilm FinePix S4800 Battery Compartment Door Replacement: 8 단계, 이미지 2개 중 1개 Fujifilm FinePix S4800 Battery Compartment Door Replacement: 8 단계, 이미지 2개 중 2개
    • Gently, remove the rear case from the camera and set it aside.
  9. Fujifilm FinePix S4800 Battery Compartment Door Replacement, Battery Compartment Door: 9 단계, 이미지 3개 중 1개 Fujifilm FinePix S4800 Battery Compartment Door Replacement, Battery Compartment Door: 9 단계, 이미지 3개 중 2개 Fujifilm FinePix S4800 Battery Compartment Door Replacement, Battery Compartment Door: 9 단계, 이미지 3개 중 3개
    • Once the rear case is removed, gently separate the battery compartment door from its position.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Lairhe Barreto Paez
회원 가입일: 02/17/17
285 평판
안내서 2개를 작성함
USF Tampa, Team S19-G4, Hoffman Spring 2017 USF Tampa, Team S19-G4, Hoffman Spring 2017 회원
USFT-HOFFMAN-S17S19G4
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 26
전체 시간: 2,963
