소개
When a camera's batteries loose their charge, they either need to be replaced or recharged. Also, whenever you want to service the camera, it's a good practice to remove the batteries before going any further with your repairs.
Rotate the camera so that the label on the base of the camera is facing up.
On the battery compartment door, there is a slider that says "open". Slide it down and push the door to the right to release the door.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 6개
This is simple. happy wheels (y).
Ruby Verma - 답글
Thank you for your guide, exactly what I need.
Alex, web dev at Casinority AU
Esto es simple. SMS API
You have an advantage over big businesses in that you’re lighter, more flexible, and faster on your feet. soap2day
y8 - superfighters nice.
