주요 콘텐츠로 건너뛰기
Fujifilm FinePix S4800 Battery Replacement
  1. Fujifilm FinePix S4800 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure that the camera is powered off before continuing.
    • Rotate the camera so that the label on the base of the camera is facing up.
    • On the battery compartment door, there is a slider that says "open". Slide it down and push the door to the right to release the door.
  2. Fujifilm FinePix S4800 Battery Replacement: 2 단계, 이미지 1/3 Fujifilm FinePix S4800 Battery Replacement: 2 단계, 이미지 2/3 Fujifilm FinePix S4800 Battery Replacement: 2 단계, 이미지 3/3
    • Remove all four batteries and set them aside.
    • When replacing the batteries, be sure to note the markings on the face of the battery compartment. These markings let you know which side of the battery ("+" or "-") needs to be facing up in each slot.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Stephen Calabrese
회원 가입일: 02/17/17
584 평판
안내서 3개 작성하였습니다
USF Tampa, Team S19-G4, Hoffman Spring 2017 USF Tampa, Team S19-G4, Hoffman Spring 2017 회원
USFT-HOFFMAN-S17S19G4
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 54
전체 시간: 2,996
