주요 콘텐츠로 건너뛰기
Fujifilm FinePix S8200 Batteries Replacement
  1. Fujifilm FinePix S8200 Batteries Replacement, Batteries: 1 단계, 이미지 1개 중 1개
    • Turn the camera upside down so you can access the battery chamber.
    • Make sure that the camera is powered off before opening the battery chamber. Not doing so could damage your memory card.
  2. Fujifilm FinePix S8200 Batteries Replacement: 2 단계, 이미지 1개 중 1개
    • Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
  3. Fujifilm FinePix S8200 Batteries Replacement: 3 단계, 이미지 1개 중 1개
    • With the battery chamber open, remove the old batteries.
    • When replacing the batteries, remember that the battery orientation is shown by the + and - marks. Each mark indicates which side of the battery faces up in the chamber.
결론
Insert your new batteries, close the battery chamber, and you're done!
작성자
1다른 기여자 명과 함께
Greg Sweeney
회원 가입일: 01/14/15
137 평판
안내서 1개를 작성함
USF Tampa, Team 7-1, Remmell Winter 2015 USF Tampa, Team 7-1, Remmell Winter 2015 회원
USFT-REMMELL-W15S7G1
4 회원들
안내서 9개를 작성함
3가이드 댓글
should there be an indicator led to show the camera is charing ?
tony smith - 답글
should the camera indicate that it is being charged ?
tony smith - 답글
When changing battery the date and time is reset. Is there a backup battery ?
BRIAN STIFF - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 25
전체 시간: 2,201
