주요 콘텐츠로 건너뛰기
Fujifilm FinePix S8200 Selector Replacement
필요한 것
  1. Fujifilm FinePix S8200 Selector  Replacement, Batteries: 1 단계, 이미지 1개 중 1개
    • Turn the camera upside down so you can access the battery chamber.
    • Make sure that the camera is powered off before opening the battery chamber. Not doing so could damage your memory card.
  2. Fujifilm FinePix S8200 Selector  Replacement: 2 단계, 이미지 1개 중 1개
    • Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
  3. Fujifilm FinePix S8200 Selector  Replacement: 3 단계, 이미지 1개 중 1개
    • With the battery chamber open, remove the old batteries.
    • When replacing the batteries, remember that the battery orientation is shown by the + and - marks. Each mark indicates which side of the battery faces up in the chamber.
  4. Fujifilm FinePix S8200 Selector  Replacement, Rear Housing Cover: 4 단계, 이미지 3개 중 1개 Fujifilm FinePix S8200 Selector  Replacement, Rear Housing Cover: 4 단계, 이미지 3개 중 2개 Fujifilm FinePix S8200 Selector  Replacement, Rear Housing Cover: 4 단계, 이미지 3개 중 3개
    • Remove the 4mm JIS #00 screws from the sides and bottom of the camera.
  5. Fujifilm FinePix S8200 Selector  Replacement: 5 단계, 이미지 3개 중 1개 Fujifilm FinePix S8200 Selector  Replacement: 5 단계, 이미지 3개 중 2개 Fujifilm FinePix S8200 Selector  Replacement: 5 단계, 이미지 3개 중 3개
    • Carefully pry away the rear housing cover with the plastic opening tool.
  6. Fujifilm FinePix S8200 Selector  Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the rear housing cover by carefully pulling it away from the camera.
  7. Fujifilm FinePix S8200 Selector  Replacement, Removing Selection Button: 7 단계, 이미지 1개 중 1개
    • To Replace the Selection button, carefully pull the button until the button has been fully detached.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Ugent Dailey
회원 가입일: 01/20/15
119 평판
안내서 1개를 작성함
1가이드 댓글
preciso dessa peça.. aonde consigo encontrar para comprar? email: smchous@hotmail.com
smchous - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 15
전체 시간: 1,352
