주요 콘텐츠로 건너뛰기
Fujifilm FinePix S8630 Flash Lid Spring Replacement
필요한 것
  1. Fujifilm FinePix S8630 Flash Lid Spring  Replacement, Battery Door: 1 단계, 이미지 1/1
    • Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
  2. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: 2 단계, 이미지 1/1
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the left side of the device as indicated by the pictures.
  3. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: 3 단계, 이미지 1/1
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the right side of the device as indicated by the pictures.
  4. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: 4 단계, 이미지 1/2 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: 4 단계, 이미지 2/2
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the camera flash lid as indicated by the picture.
    • Remove the plastic cover from the flash lid by gentle pulling them apart or using the plastic opening tool.
  5. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: 5 단계, 이미지 1/1
    • Fold the lid down in order to access and remove the final M3 x 4mm screw using your Philips Head Screwdriver.
  6. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: 6 단계, 이미지 1/3 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: 6 단계, 이미지 2/3 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: 6 단계, 이미지 3/3
    • Use the plastic opening tool to pry the back and front casings of the camera apart.
    • Once pried apart use your hands to pull off the back plate of the camera.
    • You will need to apply a little bit of force to remove the back plate.
  7. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: 7 단계, 이미지 1/3 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: 7 단계, 이미지 2/3 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: 7 단계, 이미지 3/3
    • Once the back plate is removed twist the battery cover clockwise and it should easily dislodge.
  8. Fujifilm FinePix S8630 Flash Lid Spring  Replacement, Flash Lid Spring: 8 단계, 이미지 1/2 Fujifilm FinePix S8630 Flash Lid Spring  Replacement, Flash Lid Spring: 8 단계, 이미지 2/2
    • Firmly grasp the flash bulb lid and remove the lid from the camera.
  9. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: 9 단계, 이미지 1/3 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: 9 단계, 이미지 2/3 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: 9 단계, 이미지 3/3
    • Locate the spring and grasp with the tweezers.
    • Pinch and compress the spring to remove it from the camera housing.
    • Slide the lever that was holding the spring out of the camera housing.
결론
Colton Lancsarics
회원 가입일: 02/10/16
731 평판
안내서 6개 작성하였습니다
USF Tampa, Team 3-2, Sullivan Spring 2016 USF Tampa, Team 3-2, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S3G2
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 5
전체 시간: 306
