주요 콘텐츠로 건너뛰기
Fujifilm FinePix XP10SE LCD Replacement
필요한 것
  1. Fujifilm FinePix XP10SE LCD Replacement, Lens: 1 단계, 이미지 1/1
    • Remove the screws from the lens cover
  2. Fujifilm FinePix XP10SE LCD Replacement: 2 단계, 이미지 1/1
    • Remove the screws from the side metal cover of outer case.
  3. Fujifilm FinePix XP10SE LCD Replacement: 3 단계, 이미지 1/2 Fujifilm FinePix XP10SE LCD Replacement: 3 단계, 이미지 2/2
    • Gently remove the Lens from the housing.
  4. Fujifilm FinePix XP10SE LCD Replacement, Front Cover: 4 단계, 이미지 1/3 Fujifilm FinePix XP10SE LCD Replacement, Front Cover: 4 단계, 이미지 2/3 Fujifilm FinePix XP10SE LCD Replacement, Front Cover: 4 단계, 이미지 3/3
    • Use a screwdriver to remove the four screws from the top and bottom of the camera. Remove the screws securing the lanyard as well.
    • Use a T5 Torx bit to secure the exterior decorative cover of the device.
  5. Fujifilm FinePix XP10SE LCD Replacement: 5 단계, 이미지 1/2 Fujifilm FinePix XP10SE LCD Replacement: 5 단계, 이미지 2/2
    • Use a plastic opening tool to detach the case.
  6. Fujifilm FinePix XP10SE LCD Replacement: 6 단계, 이미지 1/2 Fujifilm FinePix XP10SE LCD Replacement: 6 단계, 이미지 2/2
    • Use the plastic opening tool to cautiously pry the casing off of the camera.
  7. Fujifilm FinePix XP10SE LCD Replacement: 7 단계, 이미지 1/3 Fujifilm FinePix XP10SE LCD Replacement: 7 단계, 이미지 2/3 Fujifilm FinePix XP10SE LCD Replacement: 7 단계, 이미지 3/3
    • Carefully slide the case to the left. Avoid cracking the case on the lens.
  8. Fujifilm FinePix XP10SE LCD Replacement, LCD: 8 단계, 이미지 1/1
    • Locate the securing tabs of the housing unit.
    • Using the spongerslowly work your way around the outside of the case using the sponging tool to pry open the case.
    • *** Take extreme caution when doing this being careful not to break the securing tabs of the housing.
  9. Fujifilm FinePix XP10SE LCD Replacement: 9 단계, 이미지 1/1
    • Once the case is open locate the Ribbon cable attachment for the LCD screen.
    • Carefully ensure that the LCD screen is free from all attachments and any tape securing the ribbon cable is released.
  10. Fujifilm FinePix XP10SE LCD Replacement: 10 단계, 이미지 1/2 Fujifilm FinePix XP10SE LCD Replacement: 10 단계, 이미지 2/2
    • Gently lift up on the black securing bar of the ribbon cable in order to free it from the units motherboard, thus releasing the LCD from the computer.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Bryan
회원 가입일: 01/25/15
598 평판
안내서 5개 작성하였습니다
Pasco Hernando, Team 5-1, Prince Winter 2015 Pasco Hernando, Team 5-1, Prince Winter 2015 회원
PHSC-PRINCE-W15S5G1
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 12
전체 시간: 167
