주요 콘텐츠로 건너뛰기
Fujifilm FinePix XP10SE Rear Control Panel Replacement
필요한 것
  1. Fujifilm FinePix XP10SE Rear Control Panel Replacement, Front Cover: 1 단계, 이미지 1/3 Fujifilm FinePix XP10SE Rear Control Panel Replacement, Front Cover: 1 단계, 이미지 2/3 Fujifilm FinePix XP10SE Rear Control Panel Replacement, Front Cover: 1 단계, 이미지 3/3
    • Use a screwdriver to remove the four screws from the top and bottom of the camera. Remove the screws securing the lanyard as well.
    • Use a T5 Torx bit to secure the exterior decorative cover of the device.
  2. Fujifilm FinePix XP10SE Rear Control Panel Replacement: 2 단계, 이미지 1/2 Fujifilm FinePix XP10SE Rear Control Panel Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool to detach the case.
  3. Fujifilm FinePix XP10SE Rear Control Panel Replacement: 3 단계, 이미지 1/2 Fujifilm FinePix XP10SE Rear Control Panel Replacement: 3 단계, 이미지 2/2
    • Use the plastic opening tool to cautiously pry the casing off of the camera.
  4. Fujifilm FinePix XP10SE Rear Control Panel Replacement: 4 단계, 이미지 1/3 Fujifilm FinePix XP10SE Rear Control Panel Replacement: 4 단계, 이미지 2/3 Fujifilm FinePix XP10SE Rear Control Panel Replacement: 4 단계, 이미지 3/3
    • Carefully slide the case to the left. Avoid cracking the case on the lens.
  5. Fujifilm FinePix XP10SE Rear Control Panel Replacement, Lens: 5 단계, 이미지 1/1
    • Remove the screws from the lens cover
  6. Fujifilm FinePix XP10SE Rear Control Panel Replacement: 6 단계, 이미지 1/1
    • Remove the screws from the side metal cover of outer case.
  7. Fujifilm FinePix XP10SE Rear Control Panel Replacement: 7 단계, 이미지 1/2 Fujifilm FinePix XP10SE Rear Control Panel Replacement: 7 단계, 이미지 2/2
    • Gently remove the Lens from the housing.
  8. Fujifilm FinePix XP10SE Rear Control Panel Replacement, LCD: 8 단계, 이미지 1/1
    • Locate the securing tabs of the housing unit.
    • Using the spongerslowly work your way around the outside of the case using the sponging tool to pry open the case.
    • *** Take extreme caution when doing this being careful not to break the securing tabs of the housing.
  9. Fujifilm FinePix XP10SE Rear Control Panel Replacement: 9 단계, 이미지 1/1
    • Once the case is open locate the Ribbon cable attachment for the LCD screen.
    • Carefully ensure that the LCD screen is free from all attachments and any tape securing the ribbon cable is released.
  10. Fujifilm FinePix XP10SE Rear Control Panel Replacement: 10 단계, 이미지 1/2 Fujifilm FinePix XP10SE Rear Control Panel Replacement: 10 단계, 이미지 2/2
    • Gently lift up on the black securing bar of the ribbon cable in order to free it from the units motherboard, thus releasing the LCD from the computer.
  11. Fujifilm FinePix XP10SE Rear Control Panel Replacement, Rear Control Panel: 11 단계, 이미지 1/3 Fujifilm FinePix XP10SE Rear Control Panel Replacement, Rear Control Panel: 11 단계, 이미지 2/3 Fujifilm FinePix XP10SE Rear Control Panel Replacement, Rear Control Panel: 11 단계, 이미지 3/3
    • Locate the ribbon cable attachment for the rear panel controls.
    • Gently lift the ribbon cable securing bar and slide the ribbon cable from the socket in order to remove the rear control panel.
  12. Fujifilm FinePix XP10SE Rear Control Panel Replacement: 12 단계, 이미지 1/3 Fujifilm FinePix XP10SE Rear Control Panel Replacement: 12 단계, 이미지 2/3 Fujifilm FinePix XP10SE Rear Control Panel Replacement: 12 단계, 이미지 3/3
    • Locate the six screws on the control panel.
    • **two of the screws may be covered by tape. Remove the tape to access them.
    • Use the PH000 Phillip’s screwdriver bit from the Ifixit driver kit to remove the screws and free the control panel from the unit.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Bryan
회원 가입일: 01/25/15
598 평판
안내서 5개 작성하였습니다
Pasco Hernando, Team 5-1, Prince Winter 2015 Pasco Hernando, Team 5-1, Prince Winter 2015 회원
PHSC-PRINCE-W15S5G1
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 148
