소개
In order to keep your camera functioning properly, and working battery is vital. A dead or drained battery will prevent the camera from turning on, taking photos, using flash, etc. Replacing the battery or removing for charge is quick and simple.
필요한 것
Slide the lower silver tab labeled "1"down.
Slide the upper silver tab labeled "2"down. Once the second tab is flipped, the door will spring open.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
Hi Catherine,
Could you direct me to where I could buy a replacement battery door for the XP…exactly the same used in your video.
Many Thanks
Robert
