주요 콘텐츠로 건너뛰기
Fujifilm FinePix XP50 LCD Screen Replacement
필요한 것
  1. Fujifilm FinePix XP50 LCD Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Power off the camera.
    • Leaving the camera on while removing presents the risk of electrical shock or permanent data loss.
  2. Fujifilm FinePix XP50 LCD Screen Replacement: 2 단계, 이미지 2개 중 1개 Fujifilm FinePix XP50 LCD Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Push down on the center button and turn the dial on the side counterclockwise to open the battery compartment.
  3. Fujifilm FinePix XP50 LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the orange tab towards the hinge to release the battery.
  4. Fujifilm FinePix XP50 LCD Screen Replacement, Button: 4 단계, 이미지 2개 중 1개 Fujifilm FinePix XP50 LCD Screen Replacement, Button: 4 단계, 이미지 2개 중 2개
    • Pry the black button plate off using a plastic opening tool.
    • Buttons can fall out easily.
    • It's easiest to start from the side exposed by an open battery compartment.
    • When putting this plate back on, orientate the buttons as shown to properly fit back into the plate.
  5. Fujifilm FinePix XP50 LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the three buttons out.
  6. Fujifilm FinePix XP50 LCD Screen Replacement, Front and Back Panel: 6 단계, 이미지 1개 중 1개
    • Remove one Phillips screw with a Phillips head 0 screwdriver
    • Remove one hex head screw with a hex 1.3 screwdriver bit.
  7. Fujifilm FinePix XP50 LCD Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Unscrew two 4.0mm long hex head screws with a hex 1.3 screwdriver bit.
  8. Fujifilm FinePix XP50 LCD Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Unscrew five 4.0mm screws with a Phillips head 0 screwdriver
  9. Fujifilm FinePix XP50 LCD Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Pry the black bottom plate off using a plastic opening tool.
    • It is easier to start on the side of the open battery compartment.
  10. Fujifilm FinePix XP50 LCD Screen Replacement: 10 단계, 이미지 2개 중 1개 Fujifilm FinePix XP50 LCD Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Pry the front plate off using a plastic opening tool.
    • It's recommended to start at the ridge on the top or bottom side.
  11. Fujifilm FinePix XP50 LCD Screen Replacement: 11 단계, 이미지 1개 중 1개
    • Lift off the front plate.
  12. Fujifilm FinePix XP50 LCD Screen Replacement: 12 단계, 이미지 3개 중 1개 Fujifilm FinePix XP50 LCD Screen Replacement: 12 단계, 이미지 3개 중 2개 Fujifilm FinePix XP50 LCD Screen Replacement: 12 단계, 이미지 3개 중 3개
    • Pry the back plate off with a plastic opening tool
  13. Fujifilm FinePix XP50 LCD Screen Replacement, Back Panel: 13 단계, 이미지 1개 중 1개
    • Pry the two latches off using a spudger.
    • It takes some force to pry the latches off, so be careful to not break them.
  14. Fujifilm FinePix XP50 LCD Screen Replacement: 14 단계, 이미지 3개 중 1개 Fujifilm FinePix XP50 LCD Screen Replacement: 14 단계, 이미지 3개 중 2개 Fujifilm FinePix XP50 LCD Screen Replacement: 14 단계, 이미지 3개 중 3개
    • Pry the remaining latches with a plastic opening tool.
    • It's best to start on the opposite side. Then pry off the top and end at the bottom.
    • It may take some force to remove this, but be careful to not break the latches off.
  15. Fujifilm FinePix XP50 LCD Screen Replacement: 15 단계, 이미지 1개 중 1개
    • Pull the two halves apart.
    • Reattach the LCD ribbon cable into the slot before closing the halves when reassembling.
  16. Fujifilm FinePix XP50 LCD Screen Replacement: 16 단계, 이미지 2개 중 1개 Fujifilm FinePix XP50 LCD Screen Replacement: 16 단계, 이미지 2개 중 2개
    • Unscrew seven 4.0 mm screws with a Phillips 00 screwdriver.
    • Unscrew four 3.0 mm screws with a Phillips 00 screwdriver..
  17. Fujifilm FinePix XP50 LCD Screen Replacement, LCD Screen: 17 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to gently lift the LCD screen up.
결론
작성자
4다른 기여자 명과 함께
Cory Teixeira
회원 가입일: 03/24/17
101 평판
안내서 1개를 작성함
UMass Dartmouth, Team S7-G3, Julie Spring 2017 UMass Dartmouth, Team S7-G3, Julie Spring 2017 회원
UMASSD-JULIE-S17S7G3
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 4
지난 30일: 12
전체 시간: 520
