소개
The shutter button is the main communication point between you and your camera's main function: taking photos. When it's malfunctioning, you'll need a way to fix it. This guide will help you do just that.
필요한 것
Open the side panel which houses the battery compartment. Press the center button down and twist the dial.
Using a Phillips PH000 bit, remove the five 2mm screws on the bottom of the camera.
Once the exterior case is removed, separate the plastic depressor to ensure there is nothing lodged in or around the button, preventing proper functionality.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
Do you know where I can get replacement shutter button parts for this camera.
Where can I buy the shutter button components for this camera?
