주요 콘텐츠로 건너뛰기
Fujifilm FinePix XP80 Shutter Button Replacement
필요한 것
  1. Fujifilm FinePix XP80  Shutter Button Replacement, Battery: 1 단계, 이미지 1/3 Fujifilm FinePix XP80  Shutter Button Replacement, Battery: 1 단계, 이미지 2/3 Fujifilm FinePix XP80  Shutter Button Replacement, Battery: 1 단계, 이미지 3/3
    • Open the side panel which houses the battery compartment. Press the center button down and twist the dial.
  2. Fujifilm FinePix XP80  Shutter Button Replacement: 2 단계, 이미지 1/1
    • Release the battery from its secured position by pulling the orange tab back. The battery can then be removed from its compartment.
  3. Fujifilm FinePix XP80  Shutter Button Replacement, Exterior Case: 3 단계, 이미지 1/1
    • Using a Phillips PH000 bit, remove the five 2mm screws on the bottom of the camera.
  4. Fujifilm FinePix XP80  Shutter Button Replacement: 4 단계, 이미지 1/1
    • Using a H1.3 hex head bit, remove the two 2mm screws from the top of the camera.
  5. Fujifilm FinePix XP80  Shutter Button Replacement: 5 단계, 이미지 1/1
    • Using a H1.3 hex head bit, remove the two 2mm screws on the side of the camera.
  6. Fujifilm FinePix XP80  Shutter Button Replacement: 6 단계, 이미지 1/1
    • Using a plastic opening tool, gently pry up the edge of the button case, located at the top of the camera, until it unclips.
  7. Fujifilm FinePix XP80  Shutter Button Replacement: 7 단계, 이미지 1/1
    • Gently pry the side area of the case apart.
  8. Fujifilm FinePix XP80  Shutter Button Replacement: 8 단계, 이미지 1/1
    • Continue using the opening tool on the bottom of the camera to gently pry the case apart.
  9. Fujifilm FinePix XP80  Shutter Button Replacement: 9 단계, 이미지 1/2 Fujifilm FinePix XP80  Shutter Button Replacement: 9 단계, 이미지 2/2
    • Use the plastic opening tool to carefully pry the yellow front panel completely away from the camera.
    • Use your hands to take off the yellow back panel.
  10. Fujifilm FinePix XP80  Shutter Button Replacement, Shutter Button: 10 단계, 이미지 1/2 Fujifilm FinePix XP80  Shutter Button Replacement, Shutter Button: 10 단계, 이미지 2/2
    • Once the exterior case is removed, separate the plastic depressor to ensure there is nothing lodged in or around the button, preventing proper functionality.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Daniela Pesci
회원 가입일: 09/28/16
194 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-3, Cagle Fall 2016 USF Tampa, Team 1-3, Cagle Fall 2016 회원
USFT-CAGLE-F16S1G3
5 회원들
안내서 14개 작성하였습니다
댓글 2개
Do you know where I can get replacement shutter button parts for this camera.
DEAN MURPHY - 답글
Where can I buy the shutter button components for this camera?
DEAN MURPHY - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 736
