주요 콘텐츠로 건너뛰기
Fujifilm FinePix XP80 Interior Case Replacement
필요한 것
  1. Fujifilm FinePix XP80 Interior Case Replacement, Battery: 1 단계, 이미지 1/3 Fujifilm FinePix XP80 Interior Case Replacement, Battery: 1 단계, 이미지 2/3 Fujifilm FinePix XP80 Interior Case Replacement, Battery: 1 단계, 이미지 3/3
    • Open the side panel which houses the battery compartment. Press the center button down and twist the dial.
  2. Fujifilm FinePix XP80 Interior Case Replacement: 2 단계, 이미지 1/1
    • Release the battery from its secured position by pulling the orange tab back. The battery can then be removed from its compartment.
  3. Fujifilm FinePix XP80 Interior Case Replacement, Exterior Case: 3 단계, 이미지 1/1
    • Using a Phillips PH000 bit, remove the five 2mm screws on the bottom of the camera.
  4. Fujifilm FinePix XP80 Interior Case Replacement: 4 단계, 이미지 1/1
    • Using a H1.3 hex head bit, remove the two 2mm screws from the top of the camera.
  5. Fujifilm FinePix XP80 Interior Case Replacement: 5 단계, 이미지 1/1
    • Using a H1.3 hex head bit, remove the two 2mm screws on the side of the camera.
  6. Fujifilm FinePix XP80 Interior Case Replacement: 6 단계, 이미지 1/1
    • Using a plastic opening tool, gently pry up the edge of the button case, located at the top of the camera, until it unclips.
  7. Fujifilm FinePix XP80 Interior Case Replacement: 7 단계, 이미지 1/1
    • Gently pry the side area of the case apart.
  8. Fujifilm FinePix XP80 Interior Case Replacement: 8 단계, 이미지 1/1
    • Continue using the opening tool on the bottom of the camera to gently pry the case apart.
  9. Fujifilm FinePix XP80 Interior Case Replacement: 9 단계, 이미지 1/2 Fujifilm FinePix XP80 Interior Case Replacement: 9 단계, 이미지 2/2
    • Use the plastic opening tool to carefully pry the yellow front panel completely away from the camera.
    • Use your hands to take off the yellow back panel.
  10. Fujifilm FinePix XP80 Interior Case Replacement, Interior Case: 10 단계, 이미지 1/1
    • Using the H1.3 hex head bit, remove the four screws on the front of the camera.
  11. Fujifilm FinePix XP80 Interior Case Replacement: 11 단계, 이미지 1/1
    • Using the H1.3 hex head bit, remove the screw on the back of the camera.
  12. Fujifilm FinePix XP80 Interior Case Replacement: 12 단계, 이미지 1/1
    • Open the battery compartment on the side of the camera.
    • Using your plastic opening tool, carefully pry the two clips apart as indicated in the photo.
  13. Fujifilm FinePix XP80 Interior Case Replacement: 13 단계, 이미지 1/3 Fujifilm FinePix XP80 Interior Case Replacement: 13 단계, 이미지 2/3 Fujifilm FinePix XP80 Interior Case Replacement: 13 단계, 이미지 3/3
    • Unclip the front interior panel from the top, bottom and side of the camera.
  14. Fujifilm FinePix XP80 Interior Case Replacement: 14 단계, 이미지 1/1
    • Gently open the camera, noting the presence of two orange tapes along one side that connect the motherboard to the LCD screen.
    • Open the camera like a book and lay both sides flat next to one another, leaving the orange tapes connected.
결론
Amanda Lewis
회원 가입일: 09/25/16
317 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-3, Cagle Fall 2016 USF Tampa, Team 1-3, Cagle Fall 2016 회원
USFT-CAGLE-F16S1G3
5 회원들
안내서 14개 작성하였습니다
댓글 한 개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 422
