주요 콘텐츠로 건너뛰기
Fujifilm FinePix XP80 Lens Replacement
필요한 것
  1. Fujifilm FinePix XP80 Lens Replacement, Battery: 1 단계, 이미지 1/3 Fujifilm FinePix XP80 Lens Replacement, Battery: 1 단계, 이미지 2/3 Fujifilm FinePix XP80 Lens Replacement, Battery: 1 단계, 이미지 3/3
    • Open the side panel which houses the battery compartment. Press the center button down and twist the dial.
  2. Fujifilm FinePix XP80 Lens Replacement: 2 단계, 이미지 1/1
    • Release the battery from its secured position by pulling the orange tab back. The battery can then be removed from its compartment.
  3. Fujifilm FinePix XP80 Lens Replacement, Exterior Case: 3 단계, 이미지 1/1
    • Using a Phillips PH000 bit, remove the five 2mm screws on the bottom of the camera.
  4. Fujifilm FinePix XP80 Lens Replacement: 4 단계, 이미지 1/1
    • Using a H1.3 hex head bit, remove the two 2mm screws from the top of the camera.
  5. Fujifilm FinePix XP80 Lens Replacement: 5 단계, 이미지 1/1
    • Using a H1.3 hex head bit, remove the two 2mm screws on the side of the camera.
  6. Fujifilm FinePix XP80 Lens Replacement: 6 단계, 이미지 1/1
    • Using a plastic opening tool, gently pry up the edge of the button case, located at the top of the camera, until it unclips.
  7. Fujifilm FinePix XP80 Lens Replacement: 7 단계, 이미지 1/1
    • Gently pry the side area of the case apart.
  8. Fujifilm FinePix XP80 Lens Replacement: 8 단계, 이미지 1/1
    • Continue using the opening tool on the bottom of the camera to gently pry the case apart.
  9. Fujifilm FinePix XP80 Lens Replacement: 9 단계, 이미지 1/2 Fujifilm FinePix XP80 Lens Replacement: 9 단계, 이미지 2/2
    • Use the plastic opening tool to carefully pry the yellow front panel completely away from the camera.
    • Use your hands to take off the yellow back panel.
  10. Fujifilm FinePix XP80 Lens Replacement, Interior Case: 10 단계, 이미지 1/1
    • Using the H1.3 hex head bit, remove the four screws on the front of the camera.
  11. Fujifilm FinePix XP80 Lens Replacement: 11 단계, 이미지 1/1
    • Using the H1.3 hex head bit, remove the screw on the back of the camera.
  12. Fujifilm FinePix XP80 Lens Replacement: 12 단계, 이미지 1/1
    • Open the battery compartment on the side of the camera.
    • Using your plastic opening tool, carefully pry the two clips apart as indicated in the photo.
  13. Fujifilm FinePix XP80 Lens Replacement: 13 단계, 이미지 1/3 Fujifilm FinePix XP80 Lens Replacement: 13 단계, 이미지 2/3 Fujifilm FinePix XP80 Lens Replacement: 13 단계, 이미지 3/3
    • Unclip the front interior panel from the top, bottom and side of the camera.
  14. Fujifilm FinePix XP80 Lens Replacement: 14 단계, 이미지 1/1
    • Gently open the camera, noting the presence of two orange tapes along one side that connect the motherboard to the LCD screen.
    • Open the camera like a book and lay both sides flat next to one another, leaving the orange tapes connected.
  15. Fujifilm FinePix XP80 Lens Replacement, Lens: 15 단계, 이미지 1/1
    • Using a plastic opening tool, remove the entire lens housing.
    • Install the new lens and housing (it is replaced as a single unit).
결론
Amanda Lewis
회원 가입일: 09/25/16
317 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-3, Cagle Fall 2016 USF Tampa, Team 1-3, Cagle Fall 2016 회원
USFT-CAGLE-F16S1G3
5 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 20
전체 시간: 1,535
