주요 콘텐츠로 건너뛰기
Fujifilm FinePix Z1 Battery Replacement
  1. Fujifilm FinePix Z1 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the battery on the display screen of the camera is charged. If it is not fully charged, plug into charger and turn the camera on.
    • If the battery image on the display screen does not show then you will need to check the battery.
  2. Fujifilm FinePix Z1 Battery Replacement: 2 단계, 이미지 1/1
    • Turn the camera to the bottom and find the battery access door on the left side.
  3. Fujifilm FinePix Z1 Battery Replacement: 3 단계, 이미지 1/2 Fujifilm FinePix Z1 Battery Replacement: 3 단계, 이미지 2/2
    • Open the battery access door by pushing down and up on the spring-hinged door.
    • Check that there is no obvious damage or reason for a faulty battery.
  4. Fujifilm FinePix Z1 Battery Replacement: 4 단계, 이미지 1/1
    • Push the yellow tab to eject the battery.
  5. Fujifilm FinePix Z1 Battery Replacement: 5 단계, 이미지 1/1
    • Remove the battery and replace with a new one.
결론
Carra
회원 가입일: 01/30/18
533 평판
안내서 4개 작성하였습니다
Baylor, Team S2-G4, Johnson Spring 2018 Baylor, Team S2-G4, Johnson Spring 2018 회원
BU-JOHNSON-S18S2G4
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 20
전체 시간: 721
