주요 콘텐츠로 건너뛰기
Fujifilm FinePix Z5 LCD Screen Replacement
필요한 것
  1. Fujifilm FinePix Z5 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1/3 Fujifilm FinePix Z5 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 2/3 Fujifilm FinePix Z5 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3/3
    • Remove the two screws on the right side of the camera and the two screws on the left side.
    • Use a small #00 Phillips flat head screwdriver.
    • Keep all the screws in a container and the two different types separate.
  2. Fujifilm FinePix Z5 LCD Screen Replacement: 2 단계, 이미지 1/2 Fujifilm FinePix Z5 LCD Screen Replacement: 2 단계, 이미지 2/2
    • Remove the three screws from the bottom of the camera.
    • You need a three-prong screw driver for two of the three screws; keep these screws separate.
  3. Fujifilm FinePix Z5 LCD Screen Replacement: 3 단계, 이미지 1/3 Fujifilm FinePix Z5 LCD Screen Replacement: 3 단계, 이미지 2/3 Fujifilm FinePix Z5 LCD Screen Replacement: 3 단계, 이미지 3/3
    • Remove the back by carefully flipping it open to the right side.
    • There will be a ribbon cable attaching the front panel to the motherboard, be sure not to tear this.
  4. Fujifilm FinePix Z5 LCD Screen Replacement: 4 단계, 이미지 1/2 Fujifilm FinePix Z5 LCD Screen Replacement: 4 단계, 이미지 2/2
    • Pull the LCD screen to the left slightly, lift it and flip it open to the right.
    • There is also a ribbon cable attaching the LCD screen to the motherboard, be careful not to tear it.
  5. Fujifilm FinePix Z5 LCD Screen Replacement: 5 단계, 이미지 1/2 Fujifilm FinePix Z5 LCD Screen Replacement: 5 단계, 이미지 2/2
    • Using a small flat head screw driver, flip open the black lever to release the ribbon cable.
    • Gently slide the cable out of the lock; the LCD screen is now free to be removed.
  6. Fujifilm FinePix Z5 LCD Screen Replacement: 6 단계, 이미지 1/1
    • Using your index finger, guide the cable of the new screen into place. Lock it in by pushing the black lever back down.
결론
Kyle Kaczmar
회원 가입일: 02/10/12
14 평판
안내서 1개 작성함
James Madison, Team 3-4, Klein Spring 2012 James Madison, Team 3-4, Klein Spring 2012 회원
JMU-KLEIN-S12S3G4
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 21
전체 시간: 990
