주요 콘텐츠로 건너뛰기
Fujifilm FinePix Z5 Optical Lens Replacement
필요한 것
  1. Fujifilm FinePix Z5 Optical Lens Replacement, Optical Lens: 1 단계, 이미지 1/3 Fujifilm FinePix Z5 Optical Lens Replacement, Optical Lens: 1 단계, 이미지 2/3 Fujifilm FinePix Z5 Optical Lens Replacement, Optical Lens: 1 단계, 이미지 3/3
    • Remove the two screws from the right side of the camera and the two screws from the left side.
    • Use a small #00 Phillips flat head screwdriver.
    • Keep all the screws in a container and the two different types separate.
  2. Fujifilm FinePix Z5 Optical Lens Replacement: 2 단계, 이미지 1/1
    • Remove the three screws from the bottom of the camera.
    • Use a three-prong screwdriver for two of the three screws; keep these screws separate.
  3. Fujifilm FinePix Z5 Optical Lens Replacement: 3 단계, 이미지 1/3 Fujifilm FinePix Z5 Optical Lens Replacement: 3 단계, 이미지 2/3 Fujifilm FinePix Z5 Optical Lens Replacement: 3 단계, 이미지 3/3
    • Remove the back by carefully flipping it open to the right side.
    • There will be a ribbon cable attaching the front panel to the motherboard, be sure not to tear this.
  4. Fujifilm FinePix Z5 Optical Lens Replacement: 4 단계, 이미지 1/2 Fujifilm FinePix Z5 Optical Lens Replacement: 4 단계, 이미지 2/2
    • Pull the LCD screen to the left slightly, then lift and flip it open to the right.
    • There is an orange ribbon cable attaching the LCD screen to the motherboard, be careful not to tear it.
  5. Fujifilm FinePix Z5 Optical Lens Replacement: 5 단계, 이미지 1/2 Fujifilm FinePix Z5 Optical Lens Replacement: 5 단계, 이미지 2/2
    • Using a plastic opening tool to flip open the black lever to release the ribbon cable.
    • Gently slide the cable out of the lock; the LCD screen is now free to be removed.
  6. Fujifilm FinePix Z5 Optical Lens Replacement: 6 단계, 이미지 1/3 Fujifilm FinePix Z5 Optical Lens Replacement: 6 단계, 이미지 2/3 Fujifilm FinePix Z5 Optical Lens Replacement: 6 단계, 이미지 3/3
    • Remove the two screws that are holding the silver paneling on.
    • There is a gold foil which will tear upon removal of the silver paneling, this is normal.
    • Remove the screw anchoring the motherboard on the right.
  7. Fujifilm FinePix Z5 Optical Lens Replacement: 7 단계, 이미지 1/3 Fujifilm FinePix Z5 Optical Lens Replacement: 7 단계, 이미지 2/3 Fujifilm FinePix Z5 Optical Lens Replacement: 7 단계, 이미지 3/3
    • Detach the two ribbon cables on the left side of the camera the same way the LCD cable was detached.
    • Detach the gold ribbon cable on the top middle of the camera as well.
  8. Fujifilm FinePix Z5 Optical Lens Replacement: 8 단계, 이미지 1/3 Fujifilm FinePix Z5 Optical Lens Replacement: 8 단계, 이미지 2/3 Fujifilm FinePix Z5 Optical Lens Replacement: 8 단계, 이미지 3/3
    • Hold wires on the left with an index finger, to keep them out of the way.
    • Carefully wiggle out the motherboard. The flash and the speaker will come with it.
    • Make sure you have a motherboard that includes the flash and the speaker; these items are both soldered onto the motherboard.
  9. Fujifilm FinePix Z5 Optical Lens Replacement: 9 단계, 이미지 1/3 Fujifilm FinePix Z5 Optical Lens Replacement: 9 단계, 이미지 2/3 Fujifilm FinePix Z5 Optical Lens Replacement: 9 단계, 이미지 3/3
    • Lift the lens off of the camera base (there is nothing anchoring it down).
결론
Inga Direktorchuk
회원 가입일: 02/10/12
72 평판
안내서 2개 작성하였습니다
James Madison, Team 3-4, Klein Spring 2012 James Madison, Team 3-4, Klein Spring 2012 회원
JMU-KLEIN-S12S3G4
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 798
