주요 콘텐츠로 건너뛰기
Fujifilm FinePix Z90 Battery Replacement Replacement
  1. Fujifilm FinePix Z90 Battery Replacement Replacement, Battery Replacement: 1 단계, 이미지 1/2 Fujifilm FinePix Z90 Battery Replacement Replacement, Battery Replacement: 1 단계, 이미지 2/2
    • Open the battery cover that is located on the bottom of the camera on the right side by pushing firmly and sliding it forward. The cover should lift open.
    • Press the yellow lever to release the battery. Pull the battery out of the camera.
    • Insert the new battery and close the battery cover.
결론
Sam Clark
회원 가입일: 11/03/15
301 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 1-6, Bhusal Fall 2015 UMass Dartmouth, Team 1-6, Bhusal Fall 2015 회원
UMASSD-BHUSAL-F15S1G6
2 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 529
