소개
This guide will explain how to remove the back cover from the camera. This is the cover that is around the LCD side of the camera. Simply removing the screws and pulling apart the casing are the only steps necessary.
필요한 것
Remove the screws from the bottom of the camera using the tri-wing screwdriver.
Three 5.4 mm tri-head screws.
거의 끝나갑니다!
결론
다른 3명이 해당 안내서를 완성하였습니다.
