주요 콘텐츠로 건너뛰기
Fujifilm Finepix F10 6.3 MP Front cover Replacement
필요한 것
  1. Fujifilm Finepix F10 6.3 MP Front cover Replacement, Back Cover: 1 단계, 이미지 1/1
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Fujifilm Finepix F10 6.3 MP Front cover Replacement: 2 단계, 이미지 1/1
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Fujifilm Finepix F10 6.3 MP Front cover Replacement: 3 단계, 이미지 1/1
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Fujifilm Finepix F10 6.3 MP Front cover Replacement: 4 단계, 이미지 1/3 Fujifilm Finepix F10 6.3 MP Front cover Replacement: 4 단계, 이미지 2/3 Fujifilm Finepix F10 6.3 MP Front cover Replacement: 4 단계, 이미지 3/3
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Fujifilm Finepix F10 6.3 MP Front cover Replacement, Front cover: 5 단계, 이미지 1/1
    • Remove screws from motherboard using the Phillips 00 screwdriver.
    • Two 2.5 mm widehead Phillips screws
    • One 3.3 mm #00 Phillips screws
    • Three 2.5 mm #00 Phillips screws (black screws)
  6. Fujifilm Finepix F10 6.3 MP Front cover Replacement: 6 단계, 이미지 1/1
    • Rotate the front cover clockwise onto its side and remove the single screw on the side using a Phillips 00 screwdriver.
    • Remove 3.3 mm #00 Phillips screw from the side of the front screen.
  7. Fujifilm Finepix F10 6.3 MP Front cover Replacement: 7 단계, 이미지 1/2 Fujifilm Finepix F10 6.3 MP Front cover Replacement: 7 단계, 이미지 2/2
    • Firmly grasp both the motherboard and front cover. Slowly pull the front cover away from the motherboard.
    • Do not be alarmed if it takes substantial pressure to separate the two.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sarah Looper
회원 가입일: 03/11/13
100 평판
안내서 7개 작성하였습니다
Clemson, Team 13-4, Benson Spring 2013 Clemson, Team 13-4, Benson Spring 2013 회원
CLEM-BENSON-S13S13G4
2 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 860
