주요 콘텐츠로 건너뛰기
Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement
필요한 것
  1. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement, Back Cover: 1 단계, 이미지 1/1
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: 2 단계, 이미지 1/1
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: 3 단계, 이미지 1/1
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: 4 단계, 이미지 1/3 Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: 4 단계, 이미지 2/3 Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: 4 단계, 이미지 3/3
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement, Lens Filter Set: 5 단계, 이미지 1/2 Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement, Lens Filter Set: 5 단계, 이미지 2/2
    • Remove electrowind strip from font cover.
    • The front cover does not have to be separated from the device for this step or the next ones.
  6. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: 6 단계, 이미지 1/1
    • Remove lens data cable by gently pulling it out.
  7. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: 7 단계, 이미지 1/1
    • Remove lens filter.
    • There are multiple square pieces, so be sure to remove them all.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sarah Looper
회원 가입일: 03/11/13
100 평판
안내서 7개 작성하였습니다
Clemson, Team 13-4, Benson Spring 2013 Clemson, Team 13-4, Benson Spring 2013 회원
CLEM-BENSON-S13S13G4
2 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 799
