주요 콘텐츠로 건너뛰기
Fujifilm Finepix F10 6.3 MP Shutter Button Replacement
필요한 것
  1. Fujifilm Finepix F10 6.3 MP Shutter Button Replacement, Back Cover: 1 단계, 이미지 1/1
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: 2 단계, 이미지 1/1
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: 3 단계, 이미지 1/1
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: 4 단계, 이미지 1/3 Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: 4 단계, 이미지 2/3 Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: 4 단계, 이미지 3/3
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Fujifilm Finepix F10 6.3 MP Shutter Button Replacement, LCD: 5 단계, 이미지 1/1
    • Remove screws from the casing covering the LCD using the Phillips 00 screwdriver.
    • Remove the fifteen 2.9 mm Phillips #00 screws.
  6. Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: 6 단계, 이미지 1/1
    • Slide casing out using the spudger.
  7. Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: 7 단계, 이미지 1/2 Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: 7 단계, 이미지 2/2
    • Gently remove the LCD display data cable by gripping the end that is connected to the motherboard and pulling out.
  8. Fujifilm Finepix F10 6.3 MP Shutter Button Replacement, Shutter Button: 8 단계, 이미지 1/2 Fujifilm Finepix F10 6.3 MP Shutter Button Replacement, Shutter Button: 8 단계, 이미지 2/2
    • Pull on the shutter button display data cable on the end connected to the motherboard until it slides out.
  9. Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: 9 단계, 이미지 1/2 Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: 9 단계, 이미지 2/2
    • While slightly rotating the shutter button and data cable counter-clockwise, pull out until whole component comes out.
    • When inserting the new shutter button and data cable component, be sure it is placed properly into the camera or it will not function correctly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sarah Looper
회원 가입일: 03/11/13
100 평판
안내서 7개 작성하였습니다
Clemson, Team 13-4, Benson Spring 2013 Clemson, Team 13-4, Benson Spring 2013 회원
CLEM-BENSON-S13S13G4
2 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 1,057
