주요 콘텐츠로 건너뛰기
Fujifilm Finepix S1000fd Battery Replacement
  1. Fujifilm Finepix S1000fd Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the camera upside down.
  2. Fujifilm Finepix S1000fd Battery Replacement: 2 단계, 이미지 1/1
    • Flick the switch on the right side of the camera, and bring it downwards, while simultaneously lifting up the cover.
    • While the switch is held down, lift up the battery compartment cover.
  3. Fujifilm Finepix S1000fd Battery Replacement: 3 단계, 이미지 1/1
    • Observe that the signs on the battery compartment will show you how to insert the 4 AA batteries.
    • There should be positive battery signs near the bottom slot and the third slot from the bottom.
    • There should be negative battery signs near the top slot and the second slot from the bottom.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Somya Lalwani
회원 가입일: 01/25/17
113 평판
안내서 1개 작성함
Cal Poly, Team 8-7, Banghart Winter 2017 Cal Poly, Team 8-7, Banghart Winter 2017 회원
CPSU-BANGHART-W17S8G7
4 회원들
안내서 10개 작성하였습니다
댓글 3개
My S1000 takes 1 battery not five…
francanadaswan - 답글
My Fuji S1000 digital camera takes 1 battery, not five. Where can I get a replacement? Nothing on Amazon.
francanadaswan - 답글
My s1000fd takes 4 batteries... how would i clean it after the batteries leaked in the battery well? is it salvageable?
Beckmansbabe - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 23
전체 시간: 1,733
