소개
Use caution when going through with the procedure. This procedure involves doing operations near the motherboard of the device, which has many sensitive components.
필요한 것
Use the Phillips PH00 screwdriver to remove all the 0.5mm screws on the side.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Hi, any idea how i can get to the shutter button mechanism, it’s stopped working and I don’t want to break anything in my impatience to fix it :)
mike.osupe - 답글
