주요 콘텐츠로 건너뛰기
Fujifilm Finepix S1000fd Rear Cover Casing Replacement
필요한 것
  1. Fujifilm Finepix S1000fd Rear Cover Casing Replacement, Rear Cover Casing: 1 단계, 이미지 1/2 Fujifilm Finepix S1000fd Rear Cover Casing Replacement, Rear Cover Casing: 1 단계, 이미지 2/2
    • Use the Phillips PH00 screwdriver to remove all the 0.5mm screws on the side.
  2. Fujifilm Finepix S1000fd Rear Cover Casing Replacement: 2 단계, 이미지 1/2 Fujifilm Finepix S1000fd Rear Cover Casing Replacement: 2 단계, 이미지 2/2
    • Use the Tri-point Y0 screwdriver to remove the two 0.5mm screws on the horizontal axis.
    • Remove the other two 0.5mm screws on the bottom with the PH00 screwdriver.
  3. Fujifilm Finepix S1000fd Rear Cover Casing Replacement: 3 단계, 이미지 1/1
    • Once you unscrew all of the screws, carefully remove the rear casing.
    • Be careful not to pull the rear casing, otherwise you will rip the ribbon cable.
    • Detach the ribbon cable by lifting the tab on the connector.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Lizzie Eller
회원 가입일: 01/25/17
422 평판
안내서 4개 작성하였습니다
Cal Poly, Team 8-7, Banghart Winter 2017 Cal Poly, Team 8-7, Banghart Winter 2017 회원
CPSU-BANGHART-W17S8G7
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 16
전체 시간: 590
