주요 콘텐츠로 건너뛰기
Fujifilm Finepix S1800 Back Cover Assembly Replacement
필요한 것
  1. Fujifilm Finepix S1800 Back Cover Assembly Replacement, Back Cover Assembly: 1 단계, 이미지 1/1
    • Unscrew the four 4mm screws on the left-hand side of the camera with the JIS #1 screwdriver.
  2. Fujifilm Finepix S1800 Back Cover Assembly Replacement: 2 단계, 이미지 1/1
    • Unscrew the four 4mm screws on the right-hand side of the camera with the JIS #1 screwdriver.
  3. Fujifilm Finepix S1800 Back Cover Assembly Replacement: 3 단계, 이미지 1/1
    • Unscrew the three 4mm screws on the bottom of the camera with the JIS #1 screwdriver.
  4. Fujifilm Finepix S1800 Back Cover Assembly Replacement: 4 단계, 이미지 1/2 Fujifilm Finepix S1800 Back Cover Assembly Replacement: 4 단계, 이미지 2/2
    • Take the plastic opening tool and place it in the space between the top of the screen and the top of the camera.
    • The cover will pop out.
    • You may have to work the back cover from different sides to get it to pop off.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ryan Rockford
회원 가입일: 02/15/17
618 평판
안내서 5개 작성하였습니다
USF Tampa, Team 8-6, Eyestone Spring 2017 USF Tampa, Team 8-6, Eyestone Spring 2017 회원
USFT-EYESTONE-S17S8G6
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 16
전체 시간: 401
